AS7343 tinkering
I’ve swapped the 550 and 555 labels around as well. Here’s the current code which shows the unscaled values when in wavelength label mode.
If gadgetoid wants to use it as the example code on github, then that’s OK with me. As a naive user I havn’t worked out how to do a Pull Request on github in order to upload my example.
from AS7343 import AS7343
from picographics import PicoGraphics, DISPLAY_PICO_W_EXPLORER, PEN_P4
from pimoroni import Button
# Edits by Tony Abbey 20240909 with button Y to toggle between channel and wavelength labels, and display
# the unscaled values above the bar graphs when in wavelength mode. Max values tweaked to give
# a more even set of bars with LED on a white paper reflection.
i2c = PimoroniI2C(sda=20, scl=21)
as7343 = AS7343(i2c)
button_a = Button(12)
button_b = Button(13)
button_x = Button(14)
button_y = Button(15)
display = PicoGraphics(display=DISPLAY_PICO_W_EXPLORER, pen_type=PEN_P4, rotate=270)
display.set_font("bitmap8")
display.set_backlight(0.5)
F1 = display.create_pen(130, 0, 200)
F2 = display.create_pen(84, 0, 255)
FZ = display.create_pen(0, 70, 255)
F3 = display.create_pen(0, 192, 255)
F4 = display.create_pen(31, 255, 0)
FY = display.create_pen(179, 255, 0)
F5 = display.create_pen(163, 255, 0)
FXL = display.create_pen(255, 190, 0)
F6 = display.create_pen(255, 33, 0)
F7 = display.create_pen(255, 0, 0)
F8 = display.create_pen(171, 0, 0)
NIR = display.create_pen(97, 0, 0)
# Starting max values for auto-ranging
#f1 7186, greater
#f5 1967, greater gain
#f3 962, lower gain
#f4 3926, higher gain
#f3 2600, lower gain
#FZ 2711, lower gain
#FXL 5970, higher gain
#F6 4170, lower gain
#F7 6774, higher gain
#F8 1080, lower gain
MAX_VALUES = [
    500,
    668,
    3200,
    3000,
    4000,
    6000,
    1600,
    6000,
    5500,
    4400,
    2000,
    13226
# List order for values
ORDER = [
    "F1",
    "F2",
    "FZ",
    "F3",
    "F4",
    "FY",
    "F5",
    "FXL",
    "F6",
    "F7",
    "F8",
    "NIR"
ORDER2 = [
    "405",
    "425",
    "450",
    "475",
    "515",
    "550",
    "555",
    "600",
    "640",
    "690",
    "745",
    "855"
MARGIN = max([display.measure_text(l) for l in ORDER]) + 2
BAR_WIDTH = 16
BAR_SPACING = 4
BAR_HEIGHT = WIDTH - MARGIN
OFFSET_LEFT = int((HEIGHT - 110 - ((BAR_WIDTH + BAR_SPACING) * 12)) / 2)
WHICH_LABEL = 0
    display.set_pen(0)
    display.clear()
    readings = as7343.read()
    for i , label in enumerate(ORDER):
        reading = readings[label]
 #           print (i,label,reading)
        if reading > MAX_VALUES[i]:
          print (label,reading,MAX_VALUES[i]) #show gain control in action
        MAX_VALUES[i] = max(reading, MAX_VALUES[i])  #AGC removed
        scaled = int(reading / MAX_VALUES[i] * BAR_HEIGHT)
   #     print (label, (reading/BAR_HEIGHT)*1000)
        y = (i + 1) * (BAR_WIDTH + BAR_SPACING)
        y += OFFSET_LEFT
        display.set_pen(i + 1)
        display.rectangle(MARGIN, y, scaled, BAR_WIDTH)
        display.set_pen(WHITE)
        if WHICH_LABEL == 0:
            display.text(label, 0, y + 1)
        else:
            display.text(ORDER2[i], 0, y + 1)
            display.text(str(reading), scaled+35, y + 1)
    display.update()
    if button_b.is_pressed:
        as7343.set_illumination_led(False)
    elif button_a.is_pressed:
        as7343.set_illumination_current(4)
        as7343.set_illumination_led(True)
    elif button_x.is_pressed:
        as7343.set_illumination_current(10)
    elif button_y.is_pressed:
        WHICH_LABEL = not WHICH_LABEL
        time.sleep(0.5)
    time.sleep(0.01)
Hi guys!
It looks like you are having fun with the AS7343, I just got one and saw some basic problems.
I can’t turn off the LED. It gets brighter when turned on and increases light intensity, and it dims but does not turn off when turned off. I measure 2.5V across the LED while it is told to turn off. I wonder if it’s a defective board or how I can fix this.
