I am on my wit’s end.
I’ve got my hands on AS7343 board, even though full know that there are no AS7343 libraries for ESP32/Arduino available yet, thought that I would give it a try.
My code shown below, it gave out data of all 14 channels just fine but when I read 0xBC register it told me that the FIFO buffer is full and Wtime is too short.
I tried to increase Wtime to its maximum and reduce integration time but 0XBC register does not change.
I have no idea how to deal with this FIFO thing, it said some data might be lost but the sensor responds fine and gives out data as expected. Red channel increases while showing red items, VIS increases when light increases etc.
I tried to follow AS7341 example but can’t see what is behind the hood of those codes.
Any suggest or advice? Please,
#include <Wire.h>
#define AS7343_ADDR 0x39
// Register map based on the Python library
#define REG_ENABLE 0x80
#define REG_ATIME 0x81
#define REG_WTIME 0x83
#define REG_CONFIG 0x70
#define REG_GAIN 0xC6 // AGAIN in CFG1
#define REG_CH0_DATA 0x95
#define REG_CFG20 0xD6 // Configuration register for auto_smux
#define FIFO_MAP 0xFC //Set the FIFO map
#define REG_ASTEP 0xD4 // Astep register (low and high bytes at 0xD4 and 0xD5)
#define REG_RESET 0xFA // Software reset register
class AS7343 {
private:
uint8_t i2c_addr;
public:
AS7343(uint8_t addr = AS7343_ADDR) {
i2c_addr = addr;
bool begin() {
Wire.begin();
if (!writeRegister(0x80, 0x1B)) { // Enable power and sensor
return false;//0b01011011
if (!writeRegister(REG_RESET, 0b00000010)) { // Perform software reset
return false;
if (!writeRegister(0xD6, 0x60)) { // Set auto_smux to 3
return false;//0b01100000
if (!writeRegister(REG_WTIME, 0x5E)) { // Set WTIME to 94 (0x5E in hex)
return false;
if (!writeRegister(REG_ATIME, 0x1D)) { // Set ATIME to 29 (0x1D in hex)
return false;
if (!writeRegister(REG_ASTEP, 0x57)) { // Set ASTEP low byte to 599 (0x57 in hex)
return false;
if (!writeRegister(REG_ASTEP + 1, 0x02)) { // Set ASTEP high byte to 599 (0x02 in hex)
return false;
return true;
bool readAllChannels(uint16_t *data) {
for (int i = 0; i < 3; i++) {
if (!writeRegister(FIFO_MAP, 0x7F)) { // Write FIFO_MAP three times
return false;
Wire.beginTransmission(i2c_addr);
Wire.write(REG_CH0_DATA);
if (Wire.endTransmission() != 0) {
return false;
Wire.requestFrom(i2c_addr, 36);
if (Wire.available() < 36) {
return false;
for (int i = 0; i < 18; i++) {
uint8_t low = Wire.read();
uint8_t high = Wire.read();
data[i] = (high << 8) | low;
return true;
void displayIntegrationSettings() {
uint8_t atime = readRegister(REG_ATIME);
uint16_t astep = readRegister(REG_ASTEP) | (readRegister(REG_ASTEP + 1) << 8); // REG_ASTEP is 0xD4 and 0xD5
float integrationTime = (atime + 1) * (astep + 1) * 2.78; // Integration time in microseconds
Serial.print("ATIME: ");
Serial.println(atime);
Serial.print("ASTEP: ");
Serial.println(astep);
Serial.print("Integration Time: ");
Serial.print(integrationTime, 2); // Show two decimal places for accuracy
Serial.println(" microseconds");
uint8_t regBC = readRegister(0xBC); // Read register 0xBC
Serial.print("Register 0xBC: ");
Serial.println(regBC, BIN); // Display in binary format
uint8_t wtime = readRegister(REG_WTIME); // Read WTIME
Serial.print("WTIME: ");
Serial.println(wtime);
// Add an extra line for easier readability
Serial.println();
uint8_t readRegisterPublic(uint8_t reg) { // Expose readRegister as public
return readRegister(reg);
private:
bool writeRegister(uint8_t reg, uint8_t value) {
Wire.write(reg);
Wire.write(value);
return (Wire.endTransmission() == 0);
uint8_t readRegister(uint8_t reg) {
Wire.write(reg);
return 0;
Wire.requestFrom(i2c_addr, 1);
if (Wire.available()) {
return Wire.read();
return 0;
AS7343 sensor;
const char* spectrumNames[14] = {
"Violet1", "Violet2", "Blue", "Blue/Cyan", "Cyan", "Green",
"Yellow/Green", "Orange", "Orange/Red", "Red2", "Red3", "NIR", "VIS", "Flicker"
void setup() {
Serial.begin(115200);
if (!sensor.begin()) {
Serial.println("AS7343 initialization failed!");
while (1);
Serial.println("AS7343 initialized successfully!");
sensor.displayIntegrationSettings();
void loop() {
uint16_t spectralData[18] = {0};
if (sensor.readAllChannels(spectralData)) {
uint16_t averagedData[14] = {0};
// Average the duplicated VIS and Flicker data
averagedData[0] = spectralData[12]; // Violet1
averagedData[1] = spectralData[6]; // Violet2
averagedData[2] = spectralData[0]; // Blue
averagedData[3] = spectralData[7]; // Blue/Cyan
averagedData[4] = spectralData[8]; // Cyan
averagedData[5] = spectralData[1]; // Green
averagedData[6] = spectralData[15]; // Yellow/Green
averagedData[7] = spectralData[2]; // Orange
averagedData[8] = spectralData[9]; // Orange/Red
averagedData[9] = spectralData[13]; // Red2
averagedData[10] = spectralData[14]; // Red3
averagedData[11] = spectralData[3]; // NIR
averagedData[12] = (spectralData[4] + spectralData[10] + spectralData[16]) / 3; // VIS
averagedData[13] = (spectralData[5] + spectralData[11] + spectralData[17]) / 3; // Flicker
for (int i = 0; i < 14; i++) {
Serial.print(spectrumNames[i]);
Serial.print(": ");
Serial.println(averagedData[i]);
// Read and display 0xBC register value
uint8_t regBC = sensor.readRegisterPublic(0xBC);
// Read and display WTIME
uint8_t wtime = sensor.readRegisterPublic(REG_WTIME);
Serial.println();
} else {
Serial.println("Failed to read spectral data.");
delay(1000);
this is what its output lookalike
Violet1: 27
Violet2: 53
Blue: 186
Blue/Cyan: 270
Cyan: 351
Green: 491
Yellow/Green: 115
Orange: 607
Orange/Red: 659
Red2: 605
Red3: 143
NIR: 253
VIS: 1210
Flicker: 17998
Register 0xBC: 10000100
WTIME: 94
