Ok I love this hat except one thing. Look like someone forgot to look at rpi hardware pwm. Channel 1 pwm is pin 13 or 19 and it completely blocked by relay 1 and 2 which make it useless. If you guys can just swap relay 1 with output 3 which is literally right next to it makeboard will be much nicer. Since output is controller via Darlington technically it can create (with sinking power input) an 0 to 24v analog signal for motor and led control correct?
Anyway that what I want to do I need two 0 to 10v analog signal for led dimming and software pwm just not making the cut. So what the best way to swap these two pins? I got the board mounted on an phat stacking board not directly on rpi0.
