which I have just realised does not answer your question - but AFAICT, no, Automation HAT shouldn’t screw things up, unless the pinout documented is incomplete or the noise is due electrical interference of some sort.
Thanks for the response. As I first stated, I checked there were no clashes before I purchased both.
It also, worked correctly for a couple of days and then made the screen go funky. So, I assume there is some undocumented features that cause issues after a while. But since I dont’s have circuit diagrams for both, I can not check…
How have you connected the 2 add-ons? … the TFT requires the HAT EEPROM i2c lines to be connected (phys pin 27-28). As per HAT specs, this means that Automation HAT should on the other hand not be connected to these lines, or the TFT auto-configuration will not happen correctly at boot time.
As stated in my first post, I am using the mini Black Hat hack3r. I believed, as it was I2C, they would be fine, afterall, that IS what the Black hat is for, is it not!
If that is not the case, how DO people connect multiple hats/shields?
again, you MUST disconnect phys 27-28 for one of the HAT, it will simply not work otherwise if one of them is relying on auto-configuration on boot (see the ‘EEPROM’ description on the TFT at https://pinout.xyz/pinout/pitft_plus_35).
One way to do that would be to snip those on one of the header on the mini Black HAT. Alternatively, use a full set of wires to connect exactly the needed connections for one of the HAT.
