I have just purchased a badger 2040 w. I am not a programmer and can only amend basics. I love the id card however is there any way i can use 2 or 3 wifi networks without having to amend config files? I have wifi at home, work is differnt so i cannot uses there. To be honest at momebt i log into a hotspot on my phone but this is not ideal as keeps disconnecting every few min.
I have searched for help bu cannot find anything. Has anyone found a solution?
This is difficult to solve if you are not a programmer. You would need some logic in the program that reads multiple WLAN-configurations, and then tries to connect to them one after the other until one succeeds. Or you would use button presses to select the correct wifi-network.
This is not rocket-science but it is also not trivial. You would need at a minimum some Python skills and an understanding of the existing code to know where to change the logic.
Thanks. Seems like i will have to enrol on a course. Will see what has changed since i last programmed in basic ;)
