I am trying to move a program that works on a Pico W to my Badger W but it falls over when I try to open a socket.
>>> %Run -c $EDITOR_CONTENT
Client True 192.168.0.15
None
File "<stdin>", line 83, in <module>
File "<stdin>", line 33, in open_socket
TypeError: can't convert 'NoneType' object to str implicitly
Here is my code:
import badger2040w
badger = badger2040w.Badger2040W()
from badger2040w import WIDTH
import machine
from urllib import urequest
import gc
import qrcode
import badger_os
import network_manager
import socket
from time import sleep
ssid = 'bbbbbbbbb'
password = 'bbbbbbbb'
count = 0
def connect():
#Connect to WLAN
wlan.active(True)
wlan.connect(ssid, password)
while wlan.isconnected() == False:
print('Waiting for connection...')
sleep(1)
ip = wlan.ifconfig()[0]
print(f'Connected on {ip}')
return ip
def open_socket(ip):
# Open a socket
address = (ip, 80)
connection = socket.socket()
connection.bind(address)
connection.listen(1)
return connection
def webpage(count):
#Template HTML
html = f"""
<!DOCTYPE html>
<html>
<form action="./UP">
<input type="submit" value="UP" />
</form>
<form action="./DOWN">
<input type="submit" value="DOWN" />
</form>
<p>Count : {str(count)}</p>
</body>
</html>
return str(html)
def serve(connection):
#Start a web server
global count
client = connection.accept()[0]
request = client.recv(1024)
request = str(request)
try:
request = request.split()[1]
except IndexError:
pass
if request == '/UP?':
count = count + 1
if count > 3: count = 3
elif request =='/DOWN?':
count = count - 1
if count < 0: count = 0
html = webpage(count)
client.send(html)
client.close()
try:
ip = badger.connect()
print(ip)
connection = open_socket(ip) # Fails here
serve(connection)
except KeyboardInterrupt:
machine.reset()
I would be grateful for some help.
The code should increment and decrement the counter by pressing a button on a phone. The working Pico W code is here:
# WORKING - Pico W
import network
import socket
import machine
ssid = 'sssssssss'
password = 'ppppppppp'
count = 0
def connect():
#Connect to WLAN
wlan.active(True)
sleep(1)
return ip
# Open a socket
address = (ip, 80)
return connection
def webpage(count):
#Template HTML
html = f"""
<!DOCTYPE html>
<html>
</form>
</form>
</body>
</html>
return str(html)
#Start a web server
global count
try:
except IndexError:
pass
count = count + 1
count = count - 1
client.send(html)
client.close()
try:
ip = connect()
serve(connection)
machine.reset()
All I’m trying to do is set up the Badger W as a very simple webserver. The code works on a Pico W but not on a Badger W. What am I missing?
