Badger 2040 - the LED (marked ACT) won’t go off, even on battery power. LED blink code example doesn’t work. Otherwise all is OK. I have a BME688 attached to the device and that functions correctly. The LED stays lit even with the BME688 removed.
I fixed this bug the other day - there’s links to fixed MicroPython builds in this post:
Many thanks, Hel. So would I:
- download badger2040.py
- rename it to badger2020.1.py
- upload badger2040.1.py to the Pico
- edit my program to import badger2040.1
as I don’t see a new firmware just yet? This would be the file from:
https://github.com/pimoroni/badger2040/blob/main/firmware/PIMORONI_BADGER2040/lib/badger2040.py
Thanks,
David
Here is the link Hel was pointing to:
Many thanks, Hel. I noticed that firmware 0.0.3 was available so I tried that and the problem is resolved.
Cheers, David
