Bluetooth Controller Issue on Picade [SOLVED]
Is it possible to use a bluetooth controller with Picade instead or in addition to the Joystick? I have SN30 Pro+ paired but I’m unable to use it on Picade. On my other retropie setup it works fine. Is there some setting I need to turn on or modify to make my controller work on Picade?
Edit: Solution was to use Emulationstation input to reset controller buttons…I forgot I reset configuration on them on new system.
