Can you cut a Mote LED Stick
Trying to fit it into a project and it is beyond tight.
Can i cut these down - without major problems?
If not i will repurpose a blinkt.
How much are you wanting to cut off? :D
The short answer is yes- it should be perfectly possible to truncate the stick, even if you cut it off some LEDs. The last pixel in the string is just floating its data-out and clock-out pins. If you cut cleanly enough to avoid making any bridges with the burr from the copper layer (particularly between 5v and GND), then it should work fine.
I should only have to shave off 1 max 2.
Its a shame as it fits perfectly except for the huge micro usb connector on the cable… maybe i should just fudge one of those up! but thats too fine for my soldering skills!!!
I mentioned it to @sandyjmacdonald and he couldn’t reach for the wire cutters fast enough: https://twitter.com/Gadgetoid/status/804696814024855552
Love you guys! lol
And my reply must be at least 20 characters so i typed some more.
If it’s just a question of a couple of millimeters, something like this might make things fit: https://www.amazon.co.uk/Degree-Right-Female-Extension-Adapter/dp/B01HLZYQNI/
