Longer LED strips for MOTE
Are there any other APA 102 compatible strips that can b used with the Mote controller? I’d like longer ones if possible.
You can wire in a strip of APA102 yourself if you have a soldering iron
See the thread for some details … also, I suspect that if you have different numbers of LEDs on the connectors then some software might be confused (I know that the bit that I wrote assumed that each stick has 16 LEDs … relatively easy to change of course).
