Ahoy !
I’m thinking of getting a pHat Stack for a project
It’s not certain yet, but I might only end up using 3 of the 5 spots available on the Stack for my hats and I want to final thing to be as compact as possible
I know it sounds barbaric, but do you think it possible to cut the pHat Stack to reduce its size, or does its internal wiring makes this impossible
I assume if the pHat Stack just wires the multiple GPIO headers together it should be fine (?) but being sure would prevent me from potentially wasting money on it
Side question : is putting the Pi (zero) directly on the back of the Stack on the top GPIO header (the one you connect to ribbon cable in the image on the shop) not recommended for any reason ? again, aiming for something compact
