While trying to run curl -sS https://get.pimoroni.com/speakerphat | bash as per https://github.com/pimoroni/speaker-phat I get errors and I’ve pasted the log file below.
What do I need to do to get this script or perhaps pip to use HTTPS?
I can’t update pip for probably the same reason, and I can’t find its config file.
Downloading/unpacking sn3218
Getting page http://pypi.python.org/simple/sn3218
Could not fetch URL http://pypi.python.org/simple/sn3218: HTTP Error 403: SSL is required
Will skip URL http://pypi.python.org/simple/sn3218 when looking for download links for sn3218
Could not fetch URL http://pypi.python.org/simple/: HTTP Error 403: SSL is required
Will skip URL http://pypi.python.org/simple/ when looking for download links for sn3218
Cannot fetch index base URL http://pypi.python.org/simple/
URLs to search for versions for sn3218:
* http://pypi.python.org/simple/sn3218/
Getting page http://pypi.python.org/simple/sn3218/
Could not fetch URL http://pypi.python.org/simple/sn3218/: HTTP Error 403: SSL is required
Will skip URL http://pypi.python.org/simple/sn3218/ when looking for download links for sn3218
Could not find any downloads that satisfy the requirement sn3218
No distributions at all found for sn3218
Exception information:
File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 104, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 245, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 978, in prepare_files
url = finder.find_requirement(req_to_install, upgrade=self.upgrade)
File "/usr/lib/python2.7/dist-packages/pip/index.py", line 157, in find_requirement
raise DistributionNotFound('No distributions at all found for %s' % req)
DistributionNotFound: No distributions at all found for sn3218
Thanks.
I ended up with the following, which probably shouldn’t be trusted as I don’t know what I’m talking about. sudo pip install --upgrade -v pip -i https://pypi.python.org/simple/ followed by a reboot.
I’ve made no progress.
Can the script be updated to specify the index as per the config suggestion?
Or can someone explain why it continues to use the non-https url?
The script isn’t specifying a particular URL at all, you’re running a version of pip that, perhaps, is not aware of the existence of a secure alternative for that server. I don’t know the exact reason it’s doing what it does, but since it’s incredibly out of date I’d encourage you to solve that problem rather than work around it. For the record, pip 1.1 was released on 16 Feb 2012.
At this point, I’d recommend rolling a new SD card with Raspbian Jessie on it, ideally, since running a distribution that out of date carries with it more risks than just flaky pip installs. I understand you might have installed/configured software that you don’t want to lose though (which is why I recommend a new SD card, so things can be ported over), so…
If you want to proceed without updating you could probably just install the required libraries manually with something like: pip install -v sn3218 -i https://pypi.python.org/simple/
It might also be possible to: pip install --upgrade pip to just upgrade pip itself.
/usr/local/lib/python2.7/dist-packages/pip/_vendor/requests/packages/urllib3/util/ssl_.py:318: SNIMissingWarning: An HTTPS request has been made, but the SNI (Subject Name Indication) extension to TLS is not available on this platform. This may cause the server to present an incorrect TLS certificate, which can cause validation failures. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest/security.html#snimissingwarning.
SNIMissingWarning
/usr/local/lib/python2.7/dist-packages/pip/_vendor/requests/packages/urllib3/util/ssl_.py:122: InsecurePlatformWarning: A true SSLContext object is not available. This prevents urllib3 from configuring SSL appropriately and may cause certain SSL connections to fail. You can upgrade to a newer version of Python to solve this. For more information, see https://urllib3.readthedocs.io/en/latest/security.html#insecureplatformwarning.
Requirement already up-to-date: pip in /usr/local/lib/python2.7/dist-packages
