Hi, I am trying to run the installer
curl https://get.pimoroni.com/airdac | bash
but I am getting this error
0curl: (35) Uknown SSL protocol error in connection to pimoroni.com:443
help :(
help :(
what distribution is this on? anyhow, you can drop the https://' part but you’ll be connected via an unencrypted connection… it’s OK, but some people feel uncomfortable with that, hence the recommendation to connect over an ssl tunnel.
I am following the “Streaming AirPlay to your Pi” tutorial
Tried:
curl get.pimoroni.com/airdac | bash
I got
curl: (6) Could not resolve host: get.pimoroni.com
Tried again and it just started… strange
then that means you have a dns issue… are you able to ping say google.com, or even do an apt-get update for that matter?
yes I did the apt-get update before trying to run the installer
probably a temporary issue with your ISP, if their DNS goes down then domains can’t be resolved.
Thank you for your help :)
