Trev1
1
I am trying to download the Inky Python library using the following at the command prompt;
curl https://get.pimoroni.com/inky | bash
However, I receive the following error message;
0curl: (7) Failed to connect to get.pimoroni.com port 443: Connection timed out.
I have tried this a number of times and on different Raspberry Pi devices, but still get the same result.
Is anyone able to help me with this issue please?
Many thanks in advance.
Kind regards,
Trev
hel
2
Some of our URLs seem to be having some DNS problems at the moment, we’re working on it 😬
You should be able to install Inky from Github in the meantime:
git clone https://github.com/pimoroni/inky
cd inky
sudo ./install.sh
You might also need to enable I2C and SPI in sudo raspi-config.
Trev1
3
Many thanks for such a speedy response.
I encounter the same problem for the installation script of the explorer hat pro:
https://get.pimoroni.com/explorerhat
I failed at installing this via GitHub manually. Thanks in advance for working on this!
hel
5
get.pimoroni.com should be back up and running now :)
Adrian
6
Hi!
Had a potentially similar issue with the display-o-tron 3k install script.
The script / server had ‘permanently moved’.
The install instructions need a ‘follow redirect’ option in curl:
curl -L get.pimoroni.com/dot3k | bash
:D
