Error when installing Display-O-Tron HAT on Raspberry OS
New to the world of Raspberry Pi here. Have installed the Pi and working through ssh and were about to install the software for Display-O-Tron HAT by using the command:
curl -sS get.pimoroni.com/displayotron | bash
However I do get the following message and cannot install it.
bash: rad 1: html: No such file or catalogue
bash: rad 2: syntax error near unexpected token ”<”
'ash: rad 2: `301 Moved Permanently
Anyone had similar problem or knows what it might be?
Cheers!
Looks like the instructions are a little outdated, as get.pimoroni.com expects to use https these days (I would have expected curl to follow the redirect, but…)
Anyway:
curl -sS https://get.pimoroni.com/displayotron | bash
should get you up and running.
Wonderful, it solved the issue perfectly!
Many thanks!
