This is what I get when trying to install inky:
pi@raspberrypi:~ $ curl https://get.pimoroni.com/inky -k | bash
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 38854 100 38854 0 0 85295 0 --:–:-- --:–:-- --:–:-- 85581
This script will install everything needed to use
Inky pHAT & wHAT
Always be careful when running scripts and commands copied
from the internet. Ensure they are from a trusted source.
If you want to see what this script does before running it,
you should run: ‘curl https://get.pimoroni.com/inky’
Note: Inky pHAT & wHAT requires SPI communication
Note: Inky pHAT & wHAT requires I2C communication
Do you wish to continue? [y/N] y
Checking environment…
Updating apt indexes…
Checking hardware requirements…
Checking for packages required for GPIO control…
raspi-gpio is already installed
RPi.GPIO installed and up-to-date
SPI already enabled
Checking packages required by SPI interface…
spidev installed and up-to-date
I2C already enabled
Checking packages required by I2C interface…
Python 2 smbus installed and up-to-date
Python 3 smbus installed and up-to-date
Inky pHAT & wHAT comes with examples and documentation that you may wish to install.
Performing a full install will ensure those resources are installed,
along with all required dependencies. It may however take a while!
Do you wish to perform a full install? [y/N] y
Checking for dependencies…
python-numpy is already installed
python3-numpy is already installed
python-pil is already installed
python3-pil is already installed
python-lxml is already installed
python3-lxml is already installed
python-smbus is already installed
python3-smbus is already installed
Installing Inky pHAT & wHAT library for Python 2…
Collecting inky
Could not find a version that satisfies the requirement inky (from versions: )
No matching distribution found for inky
Python 2 library install failed!
If problems persist, visit forums.pimoroni.com for support
