I’ve got a Galactic Unicorn that I’m programming with Micropython from Thonny. I appear not to be able to use both the wireless network on the picow and the LED display at the same time. This minimal program illustrates the problem:
import network
from galactic import GalacticUnicorn
from picographics import PicoGraphics, DISPLAY_GALACTIC_UNICORN as DISPLAY
wlan.active(True)
gu=GalacticUnicorn()
If either the wlan.active(True) or gu=GalacticUnicorn() lines are commented, the program completes successfully. If both are present the program seems to get stuck so that I can’t interrupt it from Thonny and have to reset it either by pulling the USB cable or pressing the reset button on the back.
I’ve updated to the latest firmware (MicroPython 856e08b1931b88271816a2f60648f6ff332235b2, galactic_unicorn v1.20.4 on 2023-08-04; Raspberry Pi Pico W with RP2040) but it hasn’t fixed this problem.
Hmm, something odd going on there; my GU happily runs with both WiFi and Gfx under 1.20.4; the only thing I can think of (aside from being a hardware issue) is power maybe? Are you running it off a laptop that might be under-powering the port?
I am running off a laptop (2023 MacBook Air, USB-C). (To be precise, the GU is attached to the USB-A port on a dongle which in turn is connected to the Mac.)
I’m really sorry, but after flipping firmware versions back and forward to try to isolate a problem there, I can’t now reproduce the problem at all, on any firmware version!
(On the other hand this is good as my actual code now works, but it would have been nice to know why things were failing before!)
