Hi, Is it possible to use Automation pHat with CodeSys
I’ve not come across CodeSys before, but it appears you can target the Pi and manipulate the GPIO at a basic level at least.
This means you should be able to switch all 3 relays, read the digital inputs and write the digital outputs. Controlling the LEDs (an i2c device) and reading the ADC (another i2c devices) may be considerably more difficult, though.
Have you guys had any luck using Codesys with the Phat? I have given it a good try but seem to have failed. I’m using Codesys with the rpi addins and i dont see anything happening!
