Connecting thermal camera to monster m4sk
hi, I am totally new to this, I’ve got the Adafruit AMG8833 QT thermal camera. I would really appreciate some help in how to connect his into the Monster M4sk, and into what ports.
The wires I have are: 4 pin JST - SH cable (Qwiic STEMMA QT, QW/ST) and also I ordered the same but with the JST-SH to DuPont sockets.
Using the first mentioned wire, it can connect into the PDM MIC socket, and the thermal board lights up. However, the eyes are not do not appear to work with this, they just stare forward.
I wondered if anyone knows which port this needs to go in and with which cable? Thank you!
Qwiic STEMMA uses i2c, so the socket you want to use is the one marked i2c.
  • One 4 pin STEMMA JST connector for I2C connection (also Grove compatible)
The cable should only go in one way and that should end up being the correct way.
Thank you so much. I will get this. x
