again thank you very much for your input
if the sensor is made for 16 Gs, why then should not work till 16g?
16 g are a lot, but not much, depending on the usage…
ok, i’m pushing the enviro Phat outisde the “enviro” usage…but i’m sure he will survive well :)
so
i went to read and understant what the sensitivy mean and mg/LSB
datasheet write that sensitivity is 0.732 mg/LSB
you calculated the factor 0.488, which when i take raw numbers, at 1G, i got about 1360, when multiplied by 0.488 give me about 664 mg thus 0.6 g ( which strange correspond to above numbers)
now i take about the 1360 (which correspond about 1000 mg), and multiply by 0.732 mg/LSB i get 955 mg
so to get the proper number, shall i take the raw number, multiply it by 0.732?
does it make sense??
i’m only dreaming?
