Me and my Team are using the Enviro pHat for an experiment, so that we can write a paper in physics Class.
I wanted to ask if anybody knows how precisely this Sensor can measure the G values, the Height and the pressure Level.
Note that if you plan to calculate altitude, it would be determined by measuring the pressure and calculating an offset from a supplied sea level pressure value. It’s only as accurate as the offset you supply.
