Detecting someone breaking a IR beam
I need to be able to trigger a Pico to run a routine when a person walks past a museum display. I thought the best way of doing this was to implement a form of broken beam detection, ie to bounce a narrow beam of light from the device to a small mirror on a wall about 6ft away and back to a detector on the device. When someone walks by, the beam is broken, and the detector connected to the Pico triggers the routine. The coding is not a problem, but generating and detecting the beam of light is. The devices that can implement the beam generation of detection either:
A. have very limited range (measured in mm’s), or
B. quite expensive
Has anyone faced the same problem, if so how did you solve it?
Thank you
Brian
Would a Time of flight sensor work?
  • Wide field of view (63° diagonal)
  • 2-400cm range
VL53L5CX 8x8 Time of Flight (ToF) Array Sensor Breakout (pimoroni.com)
