Just make sure you include your order number so we know who it’s from. Ideally stick it on a printed sheet of paper with a link to this forum thread and mark it up “FAO: Phil Howard” so it comes my way pronto!
We’ve not put any points into the Bureaucracy skill tree yet!
Just received your Display-o-Tron HAT and tested it immediately. The backlight clearly shows up some quite serious cracks in the LCD itself- I’d wager it survived testing, but obviously didn’t survive the journey to you.
In short, it’s toast! We’ll get a new one sent out to you ASAP and I’ll find out what the score is for refunding your postage.
try ro run sudo python backlight.py in the following directory ~/Pimoroni/dot3k/dothat/basic $
Get the following any suggestions much appreciated
File “backlight.py”, line 4, in
import dothat.lcd as lcd
File “/usr/local/lib/python2.7/dist-packages/dothat/lcd.py”, line 6, in
lcd = st7036.st7036(register_select_pin=25, reset_pin=12)
File “/usr/local/lib/python2.7/dist-packages/st7036.py”, line 25, in init
self.spi.open(0, spi_chip_select)
IOError: [Errno 2] No such file or directory
I am having the same problem, I am using a raspberry Pi 3 and a DOTHat.
I have run all the example scripts and none are displaying any text, I have turned on SPI, tried setting the contrast turning the display on and off with lcd.set_display_mode and can get nothing to be displayed.
That’s a good plan, let me know what you find. In the mean time I’ll see if I recall any other common gotchas it could be. There’s always the chance of a faulty board, but it’s usually something software!
I purchased my Display-O-Tron HAT back in November 2017 and I have only just got around to trying it out with a Raspberry Pi 3b. Unfortunately it does not display any text. All the other functions work as expected. I have looked through all the threads on the subject and haven’t found anything that helps. Are they any suggestions? - Thanks.
