I’ve been wanting to try out my TMP36’s with the EnviropHAT, though can’t get it to spit out a correct temperature.
I’ve taken the all.py example and modified it to suit, though having difficulty converting the analog value to millivolts for some reason.
#!/usr/bin/env python
from envirophat import light, weather, motion, analog
import sys
def write(line):
sys.stdout.write(line)
sys.stdout.flush()
write("--- Enviro pHAT Monitoring ---")
try:
analog_values = analog.read_all() # reads all 4 inputs
millivolts = analog_values[0] * (3300.0 / 1024) # eg. 0.728 =
# 10 mv per degree
temp_C = ((millivolts - 100.0) / 10.0) - 40.0
# convert celsius to fahrenheit
temp_F = (temp_C * 9.0 / 5.0) + 32
# remove decimal point from millivolts
millivolts = "%d" % millivolts
# show only one decimal place for temprature and voltage readings
temp_C = "%.1f" % temp_C
temp_F = "%.1f" % temp_F
output = """
Temp (onboard): {t1}c
Temp (TMP36) : {t2}c
Analog: 0: {a0}
Analog: 1: {a1}
Analog: 2: {a2}
Analog: 3: {a3}
""".format(
t1 = round(weather.temperature(),2),
t2 = temp_C,
a0 = analog_values[0],
a1 = analog_values[1],
a2 = analog_values[2],
a3 = analog_values[3]
output = output.replace("\n","\n\033[K")
write(output)
lines = len(output.split("\n"))
write("\033[{}A".format(lines - 1))
time.sleep(1)
except KeyboardInterrupt:
pass
Can anyone shed any light onto this?
Cheers
