Tmp36 & Envirophat
Is there any instructions on how to add the tmp36 to the envirophat ? As in connecting it up.
see the following tutorial:
https://learn.pimoroni.com/tutorial/explorer-hat/making-a-minecraft-thermometer
… obviously the code applies to the Explorer HAT but wiring up should be the same.
Does this look right to get the temp?
import sys
import scrollphat
from envirophat import analog
scrollphat.set_brightness(2)
try:
print(“updating new temp to diplay”)
scrollphat.clear()
temp = str(analog.read(3))
scrollphat.write_string(temp,0)
length = scrollphat.buffer_len()
            for i in range(length):
                    time.sleep(0.1)
            time.sleep(2)
            scrollphat.clear()
            time.sleep(10)
    except KeyboardInterrupt:
            scrollphat.clear()
            sys.exit(-1)
to read analog input 3, you would use the following:
temp = str(analog.three.read())
