Need some help with a Python file. Enviro code
I’m running a highly modified version of the Enviro weather-and-light python example.
enviroplus-python/weather-and-light.py at master · pimoroni/enviroplus-python (github.com)
It’s what’s shown running on it on its product page.
Enviro for Raspberry Pi - Monitor your world! – Pimoroni
I’ll post my code at the end. I have two of the 0.96" SPI Color LCD (160x80) Breakouts wired up to SPI0, one used CE0 and the other CE1. It’s the same display used on the Enviro pHat.
And two BME280 Breakouts, one with its address jumper cut, wired up to i2c. There is also an LTR-559 Light & Proximity Sensor Breakout on i2c.
The left LCD is showing Temp Humidity and Pressure read out of the BME280(0x76). The right LCD is showing the Temp and Humidity read out from the BME280(0x77).
And the Light value from the LTR-559. Left will be indoor and right outdoor.
I’ve made an error somewhere and can’t see it? The Right display temperature value is being overlaid with the left temperature value, its trying to show both at the same time?
The two max min are fine and independent of each other. The two Humidity values are fine also. And the left temperature is Ok, it doesn’t follow the right side value.
I wrapped an ice cub in a zip lock bag and put it up to the outside BME280. The humidity only changed on that side. The min temp value dropped accordingly only on the right side and I could see it trying to display the correct value, it just keep getting overwritten by the left side temp value.
Warning wall of code to follow.
#!/usr/bin/env python3
import os
import sys
import numpy
import colorsys
from PIL import Image, ImageDraw, ImageFont, ImageFilter
from fonts.ttf import RobotoMedium as UserFont
import ST7735
from bme280 import BME280
from ltr559 import LTR559
import pytz
from pytz import timezone
from astral.geocoder import database, lookup
from astral.sun import sun
from datetime import datetime, timedelta
try:
    from smbus2 import SMBus
except ImportError:
    from smbus import SMBus
def calculate_y_pos(x, centre):
    """Calculates the y-coordinate on a parabolic curve, given x."""
    centre = 80
    y = 1 / centre * (x - centre) ** 2
    return int(y)
def circle_coordinates(x, y, radius):
    """Calculates the bounds of a circle, given centre and radius."""
    x1 = x - radius  # Left
    x2 = x + radius  # Right
    y1 = y - radius  # Bottom
    y2 = y + radius  # Top
    return (x1, y1, x2, y2)
def map_colour(x, centre, start_hue, end_hue, day):
    """Given an x coordinate and a centre point, a start and end hue (in degrees),
       and a Boolean for day or night (day is True, night False), calculate a colour
       hue representing the 'colour' of that time of day."""
    start_hue = start_hue / 360  # Rescale to between 0 and 1
    end_hue = end_hue / 360
    sat = 1.0
    # Dim the brightness as you move from the centre to the edges
    val = 1 - (abs(centre - x) / (2 * centre))
    # Ramp up towards centre, then back down
    if x > centre:
        x = (2 * centre) - x
    # Calculate the hue
    hue = start_hue + ((x / centre) * (end_hue - start_hue))
    # At night, move towards purple/blue hues and reverse dimming
    if not day:
        hue = 1 - hue
        val = 1 - val
    r, g, b = [int(c * 255) for c in colorsys.hsv_to_rgb(hue, sat, val)]
    return (r, g, b)
def x_from_sun_moon_time(progress, period, x_range):
    """Recalculate/rescale an amount of progress through a time period."""
    x = int((progress / period) * x_range)
    return x
def sun_moon_time(city_name, time_zone):
    """Calculate the progress through the current sun/moon period (i.e day or
       night) from the last sunrise or sunset, given a datetime object 't'."""
    city = lookup(city_name, database())
    # Datetime objects for yesterday, today, tomorrow
    utc = pytz.utc
    utc_dt = datetime.now(tz=utc)
    local_dt = utc_dt.astimezone(pytz.timezone(time_zone))
    today = local_dt.date()
    yesterday = today - timedelta(1)
    tomorrow = today + timedelta(1)
    # Sun objects for yesterday, today, tomorrow
    sun_yesterday = sun(city.observer, date=yesterday)
    sun_today = sun(city.observer, date=today)
    sun_tomorrow = sun(city.observer, date=tomorrow)
    # Work out sunset yesterday, sunrise/sunset today, and sunrise tomorrow
    sunset_yesterday = sun_yesterday["sunset"]
    sunrise_today = sun_today["sunrise"]
    sunset_today = sun_today["sunset"]
    sunrise_tomorrow = sun_tomorrow["sunrise"]
    # Work out lengths of day or night period and progress through period
    if sunrise_today < local_dt < sunset_today:
        day = True
        period = sunset_today - sunrise_today
        # mid = sunrise_today + (period / 2)
        progress = local_dt - sunrise_today
    elif local_dt > sunset_today:
        day = False
        period = sunrise_tomorrow - sunset_today
        # mid = sunset_today + (period / 2)
        progress = local_dt - sunset_today
    else:
        day = False
        period = sunrise_today - sunset_yesterday
        # mid = sunset_yesterday + (period / 2)
        progress = local_dt - sunset_yesterday
    # Convert time deltas to seconds
    progress = progress.total_seconds()
    period = period.total_seconds()
    return (progress, period, day, local_dt)
def draw_background(progress, period, day):
    """Given an amount of progress through the day or night, draw the
       background colour and overlay a blurred sun/moon."""
    # x-coordinate for sun/moon
    x = x_from_sun_moon_time(progress, period, WIDTH)
    # If it's day, then move right to left
    if day:
        x = WIDTH - x
    # Calculate position on sun/moon's curve
    centre = WIDTH / 2
    y = calculate_y_pos(x, centre)
    # Background colour
    background = map_colour(x, 80, mid_hue, day_hue, day)
    # New image for background colour
    img_left = Image.new('RGBA', (WIDTH, HEIGHT), color=background)
    # draw = ImageDraw.Draw(img)
    img_right = Image.new('RGBA', (WIDTH, HEIGHT), color=background)
    # New image for sun/moon overlay
    overlay = Image.new('RGBA', (WIDTH, HEIGHT), color=(0, 0, 0, 0))
    overlay_draw = ImageDraw.Draw(overlay)
    # Draw the sun/moon
    circle = circle_coordinates(x, y, sun_radius)
    overlay_draw.ellipse(circle, fill=(200, 200, 50, opacity))
    # Overlay the sun/moon on the background as an alpha matte
    composite = Image.alpha_composite(img_left, overlay).filter(ImageFilter.GaussianBlur(radius=blur))
    return composite
    composite = Image.alpha_composite(img_right, overlay).filter(ImageFilter.GaussianBlur(radius=blur))
    return composite
def overlay_text_left(img_left, position, text, font, align_right=False, rectangle=False):
    draw = ImageDraw.Draw(img_left)
    w, h = font.getsize(text)
    if align_right:
        x, y = position
        x -= w
        position = (x, y)
    if rectangle:
        x += 1
        y += 1
        position = (x, y)
        border = 1
        rect = (x - border, y, x + w, y + h + border)
        rect_img = Image.new('RGBA', (WIDTH, HEIGHT), color=(0, 0, 0, 0))
        rect_draw = ImageDraw.Draw(rect_img)
        rect_draw.rectangle(rect, (255, 255, 255))
        rect_draw.text(position, text, font=font, fill=(0, 0, 0, 0))
        img_left = Image.alpha_composite(img_left, rect_img)
    else:
        draw.text(position, text, font=font, fill=(255, 255, 255))
    return img_left
def overlay_text_right(img_right, position, text, font, align_right=False, rectangle=False):
    draw = ImageDraw.Draw(img_right)
    if align_right:
        x, y = position
        x -= w
        position = (x, y)
    if rectangle:
        x += 1
        y += 1
        position = (x, y)
        border = 1
        img_right = Image.alpha_composite(img_right, rect_img)
    else:
    return img_right
def analyse_pressure(pressure, t):
    global time_vals, pressure_vals, trend
    if len(pressure_vals) > num_vals:
        pressure_vals = pressure_vals[1:] + [pressure]
        time_vals = time_vals[1:] + [t]
        # Calculate line of best fit
        line = numpy.polyfit(time_vals, pressure_vals, 1, full=True)
        # Calculate slope, variance, and confidence
        slope = line[0][0]
        intercept = line[0][1]
        variance = numpy.var(pressure_vals)
        residuals = numpy.var([(slope * x + intercept - y) for x, y in zip(time_vals, pressure_vals)])
        r_squared = 1 - residuals / variance
        # Calculate change in pressure per hour
        change_per_hour = slope * 60 * 60
        # variance_per_hour = variance * 60 * 60
        mean_pressure = numpy.mean(pressure_vals)
        # Calculate trend
        if r_squared > 0.5:
            if change_per_hour > 0.5:
                trend = ">"
            elif change_per_hour < -0.5:
                trend = "<"
            elif -0.5 <= change_per_hour <= 0.5:
                trend = "-"
            if trend != "-":
                if abs(change_per_hour) > 3:
                    trend *= 2
    else:
        pressure_vals.append(pressure)
        time_vals.append(t)
        change_per_hour = 0
        trend = "-"
    # time.sleep(interval)
    return (mean_pressure, change_per_hour, trend)
def describe_pressure(pressure):
    """Convert pressure into barometer-type description."""
    if pressure < 970:
        description = "storm"
    elif 970 <= pressure < 990:
        description = "rain"
    elif 990 <= pressure < 1010:
        description = "change"
    elif 1010 <= pressure < 1030:
        description = "fair"
    elif pressure >= 1030:
        description = "dry"
    else:
        description = ""
    return description
def describe_humidity_in(humidity_in):
    """Convert relative humidity into good/bad description."""
    if 30 < humidity_in < 60:
        description = "good"
    else:
        description = "bad"
    return description
def describe_humidity_out(humidity_out):
    if 30 < humidity_out < 60:
    else:
        description = "bad"
    return description
def describe_light(light):
    """Convert light level in lux to descriptive value."""
    if light < 50:
        description = "dark"
    elif 50 <= light < 100:
        description = "dim"
    elif 100 <= light < 500:
        description = "light"
    elif light >= 500:
        description = "bright"
    return description
# Initialise the left LCD
disp_left = ST7735.ST7735(
    port=0,
    cs=0,
    dc=9,
    backlight=19,
    rotation=90,
    spi_speed_hz=10000000
disp_left.begin()
# Initialise the right LCD
disp_right = ST7735.ST7735(
    port=0,
    cs=1,
    dc=9,
    backlight=19,
    rotation=90,
disp_right.begin()
WIDTH = 160
HEIGHT = 80
# The city and timezone that you want to display.
city_name = "Halifax"
time_zone = "Canada/Atlantic"
# Values that alter the look of the background
blur = 50
opacity = 125
mid_hue = 0
day_hue = 25
sun_radius = 50
# Fonts
font_sm = ImageFont.truetype(UserFont, 12)
font_lg = ImageFont.truetype(UserFont, 14)
# Margins
margin = 3
# Set up BME280 weather sensor
bus = SMBus(1)
bme_in = BME280(0x76)
bme_out = BME280(0x77)
min_temp_in = None
max_temp_in = None
min_temp_out = None
max_temp_out = None
# Set up light sensor
ltr559 = LTR559()
# Pressure variables
pressure_vals = []
time_vals = []
num_vals = 1000
interval = 1
trend = "-"
# Keep track of time elapsed
start_time = time.time()
    path = os.path.dirname(os.path.realpath(__file__))
    progress, period, day, local_dt = sun_moon_time(city_name, time_zone)
    background = draw_background(progress, period, day)
    # Time.
    time_elapsed = time.time() - start_time
    date_string = local_dt.strftime("%B %-d")
    time_string = local_dt.strftime("%-I:%M %p")
    img_left = overlay_text_left(background, (0 + margin, 0 + margin), date_string, font_lg)
    img_left = overlay_text_left(img_left, (WIDTH - margin, 0 + margin), time_string, font_lg, align_right=True)
    img_right = overlay_text_right(background, (0 + margin, 0 + margin), date_string, font_lg)
    img_right = overlay_text_right(img_right, (WIDTH - margin, 0 + margin), time_string, font_lg, align_right=True)
    # Temperature
    temperature_in = bme_in.get_temperature()
    if time_elapsed > 30:
        if min_temp_in is not None and max_temp_in is not None:
            if temperature_in < min_temp_in:
                min_temp_in = temperature_in
            elif temperature_in > max_temp_in:
                max_temp_in = temperature_in
        else:
    #temp_string = f"{corr_temperature:.0f}°C"
    temp_string_in = f"{temperature_in:.0f}°C"
    img_left = overlay_text_left(img_left, (68, 18), temp_string_in, font_lg, align_right=True)
    spacing = font_lg.getsize(temp_string_in)[1] + 1
        range_string_in = f"{min_temp_in:.0f}-{max_temp_in:.0f}"
    else:
        range_string_in = "------"
    img_left = overlay_text_left(img_left, (68, 18 + spacing), range_string_in, font_sm, align_right=True, rectangle=True)
    temp_icon = Image.open(f"{path}/icons/temperature.png")
    img_left.paste(temp_icon, (margin, 18), mask=temp_icon)
    # Temperature
    temperature_out = bme_out.get_temperature()
        if min_temp_out is not None and max_temp_out is not None:
            if temperature_out < min_temp_out:
                min_temp_out = temperature_out
            elif temperature_out > max_temp_out:
                max_temp_out = temperature_out
        else:
    temp_string_out = f"{temperature_out:.0f}°C"
    img_right = overlay_text_right(img_right, (68, 18), temp_string_out, font_lg, align_right=True)
    spacing = font_lg.getsize(temp_string_out)[1] + 1
        range_string_out = f"{min_temp_out:.0f}-{max_temp_out:.0f}"
    else:
        range_string_out = "------"
    img_right = overlay_text_right(img_right, (68, 18 + spacing), range_string_out, font_sm, align_right=True, rectangle=True)
    img_right.paste(temp_icon, (margin, 18), mask=temp_icon)
    # Humidity
    humidity_in = bme_in.get_humidity()
    humidity_string_in = f"{humidity_in:.0f}%"
    img_left = overlay_text_left(img_left, (68, 48), humidity_string_in, font_lg, align_right=True)
    spacing = font_lg.getsize(humidity_string_in)[1] + 1
    humidity_desc_in = describe_humidity_in(humidity_in).upper()
    img_left = overlay_text_left(img_left, (68, 48 + spacing), humidity_desc_in, font_sm, align_right=True, rectangle=True)
    humidity_icon = Image.open(f"{path}/icons/humidity-{humidity_desc_in.lower()}.png")
    img_left.paste(humidity_icon, (margin, 48), mask=humidity_icon)
    # Humidity
    humidity_out = bme_out.get_humidity()
    humidity_string_out = f"{humidity_out:.0f}%"
    img_right = overlay_text_right(img_right, (68, 48), humidity_string_out, font_lg, align_right=True)
    spacing = font_lg.getsize(humidity_string_out)[1] + 1
    humidity_desc_out = describe_humidity_out(humidity_out).upper()
    img_right = overlay_text_right(img_right, (68, 48 + spacing), humidity_desc_out, font_sm, align_right=True, rectangle=True)
    humidity_icon = Image.open(f"{path}/icons/humidity-{humidity_desc_out.lower()}.png")
    img_right.paste(humidity_icon, (margin, 48), mask=humidity_icon)
    # Light
    light = ltr559.get_lux()
    light_string = f"{int(light):,}"
    img_right = overlay_text_right(img_right, (WIDTH - margin, 18), light_string, font_lg, align_right=True)
    spacing = font_lg.getsize(light_string.replace(",", ""))[1] + 1
    light_desc = describe_light(light).upper()
    img_right = overlay_text_right(img_right, (WIDTH - margin - 1, 18 + spacing), light_desc, font_sm, align_right=True, rectangle=True)
    light_icon = Image.open(f"{path}/icons/bulb-{light_desc.lower()}.png")
    img_right.paste(humidity_icon, (80, 18), mask=light_icon)
    # Pressure
    pressure = bme_in.get_pressure()
    t = time.time()
    mean_pressure, change_per_hour, trend = analyse_pressure(pressure, t)
    #pressure_string = f"{int(mean_pressure):} {trend}"
    pressure_string = f"{pressure:.0f} {trend}"
    img_left = overlay_text_left(img_left, (WIDTH - margin, 48), pressure_string, font_lg, align_right=True)
    #pressure_desc = describe_pressure(mean_pressure).upper()
    pressure_desc = describe_pressure(pressure).upper()
    spacing = font_lg.getsize(pressure_string.replace(",", ""))[1] + 1
    img_left = overlay_text_left(img_left, (WIDTH - margin - 1, 48 + spacing), pressure_desc, font_sm, align_right=True, rectangle=True)
    pressure_icon = Image.open(f"{path}/icons/weather-{pressure_desc.lower()}.png")
    img_left.paste(pressure_icon, (80, 48), mask=pressure_icon)
    # Display image
    disp_left.display(img_left)
    disp_right.display(img_right)
@Shoe
@gadgetoid
After many many trial and (syntax) error edits I got it sorted. It appears it was an issue with the background image creation. I was displaying and using the same custom background as the original weather-and-light.py example on both screens. Once I created two identical independent background images, my glitch went away. The final working code is below.
For the most part anything with
something_something_left is the left LCD (SPI0 CE0)
and
something_something_right is the right LCD (SPI0 CE1)
import os
import sys
import numpy
import colorsys
import ST7735
import pytz
try:
except ImportError:
    centre = 80
    return int(y)
    sat = 1.0
    if x > centre:
    # Calculate the hue
    if not day:
        hue = 1 - hue
        val = 1 - val
    return (r, g, b)
    return x
    utc = pytz.utc
        day = True
        day = False
    else:
        day = False
def draw_background_left(progress, period, day):
    if day:
        x = WIDTH - x
    centre = WIDTH / 2
    # Background colour
    background_left = map_colour(x, 80, mid_hue, day_hue, day)
    img_left = Image.new('RGBA', (WIDTH, HEIGHT), color=background_left)
    # Draw the sun/moon
    composite_left = Image.alpha_composite(img_left, overlay).filter(ImageFilter.GaussianBlur(radius=blur))
    return composite_left
def draw_background_right(progress, period, day):
    if day:
        x = WIDTH - x
    centre = WIDTH / 2
    # Background colour
    background_right = map_colour(x, 80, mid_hue, day_hue, day)
    img_right = Image.new('RGBA', (WIDTH, HEIGHT), color=background_right)
    # Draw the sun/moon
    composite_right = Image.alpha_composite(img_right, overlay).filter(ImageFilter.GaussianBlur(radius=blur))
    return composite_right
    if align_right:
        x, y = position
        x -= w
        position = (x, y)
    if rectangle:
        x += 1
        y += 1
        position = (x, y)
        border = 1
    else:
    return img_left
    if align_right:
        x, y = position
        x -= w
        position = (x, y)
    if rectangle:
        x += 1
        y += 1
        position = (x, y)
        border = 1
    else:
    return img_right
    port=0,
    cs=0,
    dc=9,
    #backlight=19,
    rotation=90,
disp_left.begin()
    port=0,
    cs=1,
    dc=9,
    #backlight=19,
    rotation=90,
disp_right.begin()
WIDTH = 160
HEIGHT = 80
blur = 50
opacity = 125
mid_hue = 0
day_hue = 25
sun_radius = 50
# Fonts
# Margins
margin = 3
bus = SMBus(1)
min_temp_in = None
max_temp_in = None
min_temp_out = None
max_temp_out = None
    background_left = draw_background_left(progress, period, day)
    background_right = draw_background_right(progress, period, day)
    # Time.
    img_left = overlay_text_left(background_left, (0 + margin, 0 + margin), date_string, font_lg)
    img_right = overlay_text_right(background_right, (0 + margin, 0 + margin), date_string, font_lg)
    # Temperature in
        else:
    else:
    # Temperature out
        else:
    else:
           # Display image
