Hi!
Thank you for your reply.
I reckon that’s exactly what I did, and yet the terminal showed errors linked to the lack of certain values. What’s more, Sensor.Community didn’t seem to receive any of my data – even after eight or nine hours. The default WiFi and ID details are shown on the LCD just fine, though.
The code I used is below.
Thanks again!
#!/usr/bin/env python3
import requests
import ST7735
from bme280 import BME280
# from pms5003 import PMS5003, ReadTimeoutError
from subprocess import PIPE, Popen, check_output
from PIL import Image, ImageDraw, ImageFont
from fonts.ttf import RobotoMedium as UserFont
try:
from smbus2 import SMBus
except ImportError:
from smbus import SMBus
print("""luftdaten.py - Reads temperature, pressure, humidity,
PM2.5, and PM10 from Enviro plus and sends data to Luftdaten,
the citizen science air quality project.
Note: you'll need to register with Luftdaten at:
https://meine.luftdaten.info/ and enter your Raspberry Pi
serial number that's displayed on the Enviro plus LCD along
with the other details before the data appears on the
Luftdaten map.
Press Ctrl+C to exit!
bus = SMBus(1)
# Create BME280 instance
bme280 = BME280(i2c_dev=bus)
# Create LCD instance
disp = ST7735.ST7735(
port=0,
cs=1,
dc=9,
backlight=12,
rotation=270,
spi_speed_hz=10000000
# Initialize display
disp.begin()
# Create PMS5003 instance
# pms5003 = PMS5003()
# Read values from BME280 and PMS5003 and return as dict
def read_values():
values = {}
cpu_temp = get_cpu_temperature()
raw_temp = bme280.get_temperature()
comp_temp = raw_temp - ((cpu_temp - raw_temp) / comp_factor)
values["temperature"] = "{:.2f}".format(comp_temp)
values["pressure"] = "{:.2f}".format(bme280.get_pressure() * 100)
values["humidity"] = "{:.2f}".format(bme280.get_humidity())
return values
# Get CPU temperature to use for compensation
def get_cpu_temperature():
process = Popen(['vcgencmd', 'measure_temp'], stdout=PIPE, universal_newlines=True)
output, _error = process.communicate()
return float(output[output.index('=') + 1:output.rindex("'")])
# Get Raspberry Pi serial number to use as ID
def get_serial_number():
with open('/proc/cpuinfo', 'r') as f:
for line in f:
if line[0:6] == 'Serial':
return line.split(":")[1].strip()
# Check for Wi-Fi connection
def check_wifi():
if check_output(['hostname', '-I']):
return True
else:
return False
# Display Raspberry Pi serial and Wi-Fi status on LCD
def display_status():
wifi_status = "connected" if check_wifi() else "disconnected"
text_colour = (255, 255, 255)
back_colour = (0, 170, 170) if check_wifi() else (85, 15, 15)
id = get_serial_number()
message = "{}\nWi-Fi: {}".format(id, wifi_status)
img = Image.new('RGB', (WIDTH, HEIGHT), color=(0, 0, 0))
draw = ImageDraw.Draw(img)
size_x, size_y = draw.textsize(message, font)
x = (WIDTH - size_x) / 2
y = (HEIGHT / 2) - (size_y / 2)
draw.rectangle((0, 0, 160, 80), back_colour)
draw.text((x, y), message, font=font, fill=text_colour)
disp.display(img)
# def send_to_luftdaten(values, id):
# pm_values = dict(i for i in values.items() if i[0].startswith("P"))
# temp_values = dict(i for i in values.items() if not i[0].startswith("P"))
# pm_values_json = [{"value_type": key, "value": val} for key, val in pm_values.items()]
# temp_values_json = [{"value_type": key, "value": val} for key, val in temp_values.items()]
# resp_1 = requests.post(
# "https://api.luftdaten.info/v1/push-sensor-data/",
# json={
# "software_version": "enviro-plus 0.0.1",
# "sensordatavalues": pm_values_json
# headers={
# "X-PIN": "1",
# "X-Sensor": id,
# "Content-Type": "application/json",
# "cache-control": "no-cache"
resp_2 = requests.post(
json={
"sensordatavalues": temp_values_json
headers={
"X-PIN": "11",
"X-Sensor": id,
if resp_1.ok and resp_2.ok:
return True
else:
return False
# Compensation factor for temperature
comp_factor = 2.25
# Raspberry Pi ID to send to Luftdaten
id = "raspi-" + get_serial_number()
# Width and height to calculate text position
WIDTH = disp.width
HEIGHT = disp.height
# Text settings
font_size = 16
font = ImageFont.truetype(UserFont, font_size)
print("Raspberry Pi serial: {}".format(get_serial_number()))
print("Wi-Fi: {}\n".format("connected" if check_wifi() else "disconnected"))
time_since_update = 0
update_time = time.time()
# Main loop to read data, display, and send to Luftdaten
try:
time_since_update = time.time() - update_time
values = read_values()
print(values)
if time_since_update > 145:
resp = send_to_luftdaten(values, id)
print("Response: {}\n".format("ok" if resp else "failed"))
display_status()
except Exception as e:
print(e)
