PMS5003 No Output
Setting up an enviro+ with PMS5003.
After doing a pip install configparser, the installer seemed to work and all the sensors EXCEPT the PMS5003 (the main reason I bought the thing).
When I run the particulates example, all I see is “Press Ctrl-c to exit”.
If I run all-in-one, after a few taps, I see
File “all-in-one.py”, line 188, in
data = pms5003.read()
File “build/bdist.linux-armv6l/egg/pms5003/init.py”, line 121, in read
pms5003.ReadTimeoutError: PMS5003 Read Timeout
The fan is running on the PMS, but I can’t see anything beyond that
Help?
Found the solution - turns out that software is connected to /dev/ttyS0; but, the software is reading /dev/ttyAMA0.
So, as root:
mv /dev/ttyAMA0
ln /dev/ttyS0 /dev/ttyAMA0
Works like a champ.
Would still like to understand WHY…
I am so glad that you figured this out. I think that I am having the same problem.
All I get it this…
^Cpi@raspberrypi:~/enviroplus-python/examples $ python particulates.py
particulates.py - Print readings from the PMS5003 particulate sensor.
Press Ctrl+C to exit!
The trouble is that I am very new to python and am not sure how to implement your answer. Can anyone point me to some docs ?
Many Thanks
OMG So sorry , I rebooted and now it is working…
Ok
I also problem with sensor. I get :
“pms5003.SerialTimeoutError: PMS5003 Read Timeout: Failed to read start of frame byte”
running particulates.py on Pi Zero and Enviro+
I have checked the cable for continuity, and reinstalled it.
The fan in the plantower sensor box is running.
If the sensor box is not plugged in to the enviro+ and I run particulates.py I get the same message.
Help!
