I’m new to Raspberry Pi4 and have an issue with PMS5003 sensor.
I bought Raspberry Pi4, Enviro+ and PMS5003 a few days ago. Although I was able to run all examples from GitHub - pimoroni/enviroplus-python: Python library for the Enviro+ environmental monitoring board (light.py, weather.py etc.), I’m still facing issues with running particulates.py. When I run particulates.py I have the following exception:
2023-12-10 12:26:49.325 INFO particulates.py - Print readings from the PMS5003 particulate sensor.
Press Ctrl+C to exit!
File “/usr/lib/python3/dist-packages/serial/serialposix.py”, line 322, in open
self.fd = os.open(self.portstr, os.O_RDWR | os.O_NOCTTY | os.O_NONBLOCK)
FileNotFoundError: [Errno 2] No such file or directory: ‘/dev/ttyAMA0’
During handling of the above exception, another exception occurred:
File “/home/raspberry/enviro+/enviroplus-python/examples/particulates.py”, line 18, in
pms5003 = PMS5003()
File “/home/raspberry/.local/lib/python3.11/site-packages/pms5003/init.py”, line 112, in init
self.setup()
File “/home/raspberry/.local/lib/python3.11/site-packages/pms5003/init.py”, line 118, in setup
self._serial = serial.Serial(self._device, baudrate=self._baudrate, timeout=4)
File “/usr/lib/python3/dist-packages/serial/serialutil.py”, line 244, in init
self.open()
File “/usr/lib/python3/dist-packages/serial/serialposix.py”, line 325, in open
raise SerialException(msg.errno, “could not open port {}: {}”.format(self._port, msg))
serial.serialutil.SerialException: [Errno 2] could not open port /dev/ttyAMA0: [Errno 2] No such file or directory: ‘/dev/ttyAMA0’
It says that /dev/ttyAMA0 is missing. Have I misconfigured something? In addition, I can tell you that I observed that the sensor’s fan works when I turn on Raspberry, but it stops after running particulates.py.
Tech notes.
I updated Raspbian just after unpacking my Raspberry.
I use pms5003 == 0.0.5 and st7735 == 0.0.5.
