Enviro+ bme280 Library import in Weather.py
I have just received an Enviro+ and following the “Getting started” instructions. I am using a Pi Zero running Raspbian Jessie. When I try to run the weather.py example I get the following
pi@raspberrypi:~/enviroplus-python/examples $ python weather.py
File “weather.py”, line 4, in
from bme280 import BME280
ImportError: No module named bme280
Looks like I need to install the bme280 library manually as it does not happen during the install script.
git clone https://github.com/pimoroni/enviroplus-python
cd enviroplus-python
sudo ./install.sh
Where do I get the bme280 library?
Fixed!!
Found a Pimoroni bme280 library in github and installed it from there.For anyone else having this problem. Install the library as per the following.
git clone https://github.com/pimoroni/bme280-python
cd bme280-python
sudo ./install.sh
I also found you have to manually install the light and the PMS5003 libraries. The gas library is missing and can’t find it in the list of libraries.
Cheers
curl -sSL https://get.pimoroni.com/enviroplus | bash
Should install everything needed?
Thanks. Will give it a go.
Maybe the tutorial which uses
sudo ./install.sh
needs to be updated. Many hours wasted.
This is really bizarre, since the bme280 library is a dependency of the enviroplus installer… oh dear I wonder if I’ve broken something by having the install_requires in setup.py but also having a setup.cfg
Yes
works with all libraries now accessible.
Bit hard to keep my mind on this topic with the poms in a good position against the aussies in the World Cup at the moment. Cheers
Thats good to hear. Now you can have some fun with your Enviro +.
I’ve updated the library’s setup.cfg to - hopefully - prevent this happening. This is what I get for rolling out experimental packaging improvements to a popular new software repository.
Phil, I for one appreciate everything you do. Making mistakes just proves your human, lol. :P =)
Just a quick add as I have just hacked my new Enviro+ into existance and in case any other newbies are struggling.
Don’t use the git clone approach that is in the Getting started article, use the curl
There is still one error in the script, installing the modules for python3. You might not notice as all the examples are for python.
To fix this run the extra command
$ python3 -m pip install pimoroni-bme280 pms5003 ltr559 st7735 ads1015
This installs the modules for python3
It is a great bit of kit and I will do a better write up later.
