A noob here, both to Pi and HATs. I soldered a GPIO Header and connected the Enviro+ and did stuff according to here. But when I run any example I get the error “Module xxxx not found”. What could be the issue? Does Enviro+ has lights or anything to show it is getting power? Also, as I said, I am a novice and I am not 100% confident my soldering is good, so I attached an image.
Any help is appreciated.
Thanks in advance
Which module, specifically?
Normally they’re just a “pip install” or “apt install” away, but our installer should be handling all that for you.
Thank you.
All the modules give the error. I installed according to the tutorial using
git clone https://github.com/pimoroni/enviroplus-python
cd enviroplus-python
sudo ./install.sh
Then executed all the examples. All of them give “module [specific to each example] not found”
Specifically, if I run
python weather.py
I get
File “weather.py”, Line 4, in “module”
from bme280 import BME280
ImportError: No module named bme280
(Replace “module” with <module&> (here no & also))
You’re not the first person to have this problem. I have a feeling I’ve broken something.
I am sorry but what do you mean?
Just pushed an attempted fix. In your enviroplus-python github folder run:
git pull origin master
sudo ./install.sh
And see if that fixes the missing requirements.
Edit: Otherwise you should be able to fix with:
sudo pip install pimoroni-bme280 pms5003 ltr559 st7735 ads1015
Thanks. It seems I am getting another issue I resolved earlier where I get error “can not resolve github.com”
I’ll reply back as soon as I fix this access issue and execute commands you mentioned.
