Have an Enviro on a Raspberry Pi Zero 2 W. Node-Red installed and publishing temperature via MQTT successfully. I would like to use the display to show the temperature and time but cannot figure out how to use the display. I see it needs the ST7735 library to use it via Python but want to drive it directly from Node-Red. Any info to point me in the right direction would be greatly appreciated. I am fairly green to coding in general and Java Script. Using Node-Red as a tool to get me thinking programmatically.
Hi patofoto
Did you solve this issue. I am looking too :)
