I have an Enviro Indoor up and running but would like to change from a JSON upload to an MQTT before sending data to Influx.
My MQTT is running, I can subscribe to a self-made topic and see the message in another ssh connection.
I have updated the Enviro Indoor to connect to MQTT, sending a message every 1 m. No error in the log.
I am using MQTT Explore, where I can see messages received by the broker.
My problem is that I can’t figure out what topic I should subscribe to?
In Enviro Confiq the nickname is ‘enviro’.
When using MQTT Explore, I get this
The topic name is enviro/{nickname} so if you have the nickname “weather1” when you set it up, can get it from the config file, then topic would be
enviro/weather1
So in your case if the nickname is enviro it would be:
enviro/enviro
Can i confirm that if I want to read the temperature value and my enviro indoor is nicknamed “mooroom” the topic I should be listening for is
enivro/mooroom/temperature
