Enviro urban, micropython & Chromebook
I’m trying to connect to an Enviro Urban using VS Code on a Chromebook.
The device is connected as /dev/ttyACM0 and the permissions are set correctly.
I can view and edit the files on the device, but I can’t run any commands in the REPL.
I’ve tried this before on a Windows laptop and when I issue:
import enviro
I get a banner displayed in the REPL when it loads the library.
Nothing is happening on the Chromebook. I have also tried on a Pi400 using Thonny and I get the same behaviour.
I’ve attached a screenshot.
Any suggestions on what to try?
Steve
“Nothing” is not correct: the code is complaining about a method not available in the module.
Try
import enviro
dir(enviro)
This should give you a list of all the methods (and some more stuff) of the enviro module. Seems that upload_readings is not a method of this module?!
The ‘nothing’ refers to the fact that no banner appears when importing the enviro module, which I do get in VS Code on a Windows laptop.
The method is available in that library, this is snippet from main.py on the board:
# check if we've reached the time to upload our cached data
cache_file_count = enviro.cached_upload_count()
if cache_file_count >= config.upload_frequency:
  logging.info(f"> {cache_file_count} cache files need uploading")
  enviro.upload_readings()
enviro.sleep(config.reading_frequency)
Running dir(enviro) gave me this:
It seems it is picking up a different version of the enviro-module. If you look at your output, there is no upload_readings in the list. You should check the system if there are multiple versions on the device.
What firmware version are you running on the board?
