Enviro Weather UF2
I ‘provisioned’ my Enviro Weather Pico but it failed to connect to the WiFi. I went to Troubleshooting and decided to get the latest Firmware. I copied pimoroni-picow_enviro-v1.19.10-micropython-v0.0.9.UF2 and pasted it to the RPI-RP2 folder but after the copy is complete, nothing happens. I know with my other PICO W the folder closes and the PICO reboots but that didn’t happen here.
Any suggestions?
I pasted the latest Micropython pimoroni-picow_enviro-v1.19.16-micropython.UF2. This closed the folder to close but no activity. can’t get it to go to provisioning.
I was able to get a RPI PICO UF2 to install.
Still no luck with Pimoroni UF2’s.
Should I be addressing this problem somewhere else or trying to return this to the Canadian distributor I purchased it from?
Hmm, what computer are you using to copy the uf2 across? I know our production folks have had trouble copying these big prebuilt .uf2 files from the Raspberry Pi that we use for flashing/testing - could be worth trying with another machine?
(or trying a manual installation as described here: enviro/upgrading-firmware.md at main · pimoroni/enviro · GitHub )
Thanks for the tip @hel. I was trying to copy from a PI400. I then tried from a MAC and was able to get pimoroni-picow_enviro-v1.19.10-micropython-v0.0.9.UF2 pasted and provisioned.
One follow on is that I have the activity light on but also the warning light. I’ve re-provisioned but no change.
I moved the Enviro weather from the MAC back to the PI400
Thonny doesn’t connect to it.
rshell says there are no Micropython boards.
pyboard says “failed to access /dev/ttyACM0”
How can I get a the files
I shutdown and powered up the PI400 and was able to access the Enviro Weather board.
