Post removed, no longer required.
Thank you.
First, you should investigate the format()
method of strings, full documentation here: https://docs.python.org/3/library/string.html#formatstrings
Your entire string should be built up using "".format()
and you shouldn’t use +
at all.
Second, you should look into how to use write_string
since at the moment you’re passing in a string of "On"
and then attempting to supply the rest of your string as an x position: http://docs.pimoroni.com/scrollphathd/#write-a-text-string
This is a good argument for string format- since your current +
concatenated string is so visually busy to parse at a glance, you may not have noticed that comma crept in and made most of your string the second parameter to the function call.
