Error while compiling mlx90640-library
Hi all. Trying to compile mlx90640-library on the latest raspbian I get the following:
sudo apt-get install libi2c-dev
Paketlisten werden gelesen… Fertig
Abhängigkeitsbaum wird aufgebaut.
Statusinformationen werden eingelesen… Fertig
libi2c-dev ist schon die neueste Version (3.1.2-3).
0 aktualisiert, 0 neu installiert, 0 zu entfernen und 0 nicht aktualisiert.
===> is already newest version // I2C is enabled …
pi@rpi-touch-1:~/mlx90640-library $ make clean
rm -f test step fbuf interp video
rm -f examples/.o
rm -f examples/lib/
.o
rm -f functions/*.o
rm -f *.o
rm -f *.so
rm -f test
rm -f *.a
pi@rpi-touch-1:~/mlx90640-library $ make I2C_MODE=LINUX
g++ -I. -std=c++11 -std=c++11 -c -o examples/test.o examples/test.cpp
g++ -I. -std=c++11 -fPIC -I headers -shared -c -o functions/MLX90640_API.o functions/MLX90640_API.cpp
g++ -I. -std=c++11 -fPIC -I headers -shared -c -o functions/MLX90640_LINUX_I2C_Driver.o functions/MLX90640_LINUX_I2C_Driver.cpp
In file included from functions/MLX90640_LINUX_I2C_Driver.cpp:24:0:
/usr/include/linux/i2c.h:68:8: error: redefinition of ‘struct i2c_msg’
struct i2c_msg {
In file included from functions/MLX90640_LINUX_I2C_Driver.cpp:23:0:
/usr/include/linux/i2c-dev.h:37:8: error: previous definition of ‘struct i2c_msg’
struct i2c_msg {
/usr/include/linux/i2c.h:131:7: error: redefinition of ‘union i2c_smbus_data’
union i2c_smbus_data {
/usr/include/linux/i2c-dev.h:89:7: error: previous definition of ‘union i2c_smbus_data’
functions/MLX90640_LINUX_I2C_Driver.cpp: In function ‘int MLX90640_I2CRead(uint8_t, uint16_t, uint16_t, uint16_t*)’:
functions/MLX90640_LINUX_I2C_Driver.cpp:51:27: error: invalid conversion from ‘__u8* {aka unsigned char*}’ to ‘char*’ [-fpermissive]
i2c_messages[0].buf = (__u8*)cmd;
functions/MLX90640_LINUX_I2C_Driver.cpp:56:27: error: invalid conversion from ‘__u8* {aka unsigned char*}’ to ‘char*’ [-fpermissive]
i2c_messages[1].buf = (__u8*)buf;
functions/MLX90640_LINUX_I2C_Driver.cpp: In function ‘int MLX90640_I2CWrite(uint8_t, uint16_t, uint16_t)’:
functions/MLX90640_LINUX_I2C_Driver.cpp:93:27: error: invalid conversion from ‘__u8* {aka unsigned char*}’ to ‘char*’ [-fpermissive]
: die Regel für Ziel „functions/MLX90640_LINUX_I2C_Driver.o“ scheiterte
make: *** [functions/MLX90640_LINUX_I2C_Driver.o] Fehler 1
Any ideas where to look next?
Regards,
Torsten.
Try commenting out #include <linux/i2c.h> in functions/MLX90640_LINUX_I2C_Driver.cpp - I don’t think both of those includes are needed.
I have a similar problem and more:
root@RPi3AP:/temp/mlx90640-library# uname -a
Linux RPi3AP 4.14.97-v7+ #1197 SMP Mon Feb 4 21:13:29 GMT 2019 armv7l GNU/Linux
root@RPi3AP:/temp/mlx90640-library# make clean
rm -f examples/.o
rm -f examples/lib/
.o
rm -f functions/.o
rm -f .o
rm -f .so
rm -f test
rm -f .a
root@RPi3AP:/temp/mlx90640-library# make I2C_MODE=LINUX
ar rcs libMLX90640_API.a functions/MLX90640_API.o functions/MLX90640_LINUX_I2C_Driver.o
ranlib libMLX90640_API.a
g++ -L/home/pi/mlx90640-library examples/test.o libMLX90640_API.a -o test
g++ -I. -std=c++11 -std=c++11 -c -o examples/step.o examples/step.cpp
g++ -L/home/pi/mlx90640-library examples/step.o libMLX90640_API.a -o step
g++ -I. -std=c++11 -std=c++11 -c -o examples/fbuf.o examples/fbuf.cpp
cc -c -o examples/lib/fb.o examples/lib/fb.c
g++ -L/home/pi/mlx90640-library examples/fbuf.o examples/lib/fb.o libMLX90640_API.a -o fbuf
g++ -I. -std=c++11 -std=c++11 -c -o examples/interp.o examples/interp.cpp
g++ -std=c++11 -c -o examples/lib/interpolate.o examples/lib/interpolate.c
g++ -L/home/pi/mlx90640-library examples/interp.o examples/lib/interpolate.o examples/lib/fb.o libMLX90640_API.a -o interp
g++ -I. -std=c++11 -std=c++11 -c -o examples/video.o examples/video.cpp
examples/video.cpp: In function ‘void video_encode_start(const char
, int, AVCodecID)’:
examples/video.cpp:118:25: warning: ‘AVStream::codec’ is deprecated [-Wdeprecated-declarations]
if (video_avstream->codec == NULL) {
In file included from examples/video.cpp:21:0:
/usr/include/arm-linux-gnueabihf/libavformat/avformat.h:893:21: note: declared here
AVCodecContext *codec;
examples/video.cpp:124:25: warning: ‘AVStream::codec’ is deprecated [-Wdeprecated-declarations]
c = video_avstream->codec;
examples/video.cpp: In function ‘void video_encode_frame(int)’:
examples/video.cpp:207:11: warning: ‘int avcodec_encode_video2(AVCodecContext
, AVPacket
, const AVFrame
, int*)’ is deprecated -Wdeprecated-declarations]
ret = avcodec_encode_video2(c, &pkt, frame, &got_output);
In file included from examples/video.cpp:15:0:
/usr/include/arm-linux-gnueabihf/libavcodec/avcodec.h:5333:5: note: declared here
int avcodec_encode_video2(AVCodecContext *avctx, AVPacket *avpkt,
examples/video.cpp:207:60: warning: ‘int avcodec_encode_video2(AVCodecContext*, AVPacket*, const AVFrame*, int*)’ is deprecated -Wdeprecated-declarations]
examples/video.cpp:221:3: warning: ‘void av_free_packet(AVPacket*)’ is deprecated [-Wdeprecated-declarations]
av_free_packet(&pkt);
/usr/include/arm-linux-gnueabihf/libavcodec/avcodec.h:4483:6: note: declared here
void av_free_packet(AVPacket *pkt);
examples/video.cpp:221:22: warning: ‘void av_free_packet(AVPacket*)’ is deprecated [-Wdeprecated-declarations]
examples/video.cpp: In function ‘void video_encode_end()’:
examples/video.cpp:242:48: warning: ‘AVStream::codec’ is deprecated [-Wdeprecated-declarations]
av_freep(&avFormatContext->streams[i]->codec);
examples/video.cpp: In function ‘void video_encode_start(const char*, int, AVCodecID)’:
examples/video.cpp:195:49: warning: ignoring return value of ‘int avformat_write_header(AVFormatContext*, AVDictionary**)’, declared with attribute warn_unused_result [-Wunused-result]
avformat_write_header(avFormatContext, &params);
g++ -L/home/pi/mlx90640-library examples/video.o examples/lib/fb.o libMLX90640_API.a -o video -lavcodec -lavutil -lavformat
examples/video.o: In function pulse()': video.cpp:(.text+0xc94): undefined reference tobcm2835_gpio_write’
video.cpp:(.text+0xcc8): undefined reference to bcm2835_gpio_write' examples/video.o: In functionmain’:
video.cpp:(.text+0xd10): undefined reference to bcm2835_init' video.cpp:(.text+0xd1c): undefined reference tobcm2835_gpio_fsel’
video.cpp:(.text+0x111c): undefined reference to `bcm2835_close’
collect2: error: ld returned 1 exit status
Makefile:43: recipe for target ‘video’ failed
make: *** [video] Error 1
@janeksz quick fix, find this line in the Makefile:
$(CXX) -L/home/pi/mlx90640-library $^ -o $@ $(I2C_LIBS) -lavcodec -lavutil -lavformat
And add -lbcm2835 to the end.
Or, right at the very top of the Makefile find:
ifeq ($(I2C_MODE), LINUX)
	I2C_LIBS =
endif
And remove those lines.
The issue is that it’s assuming the bcm2835 library is used only for the non-generic I2C_MODE and isn’t linking against it when you specify I2C_MODE=LINUX. For the video example this isn’t the case, since it uses bcm2835 functions to pulse a GPIO pin as an oscilloscope trigger- redundant code I need to remove.
Thanks,much appreciate your work and help. I’m trying to visualize it in nodered. Have you done anything similar or can you give me some hints? Cheers, Jan
Hi! I ran into the exact same problem as GobLin77. I tried the solution you offered and some of the errors went away. Yet, 3 of them still prevent me from compiling:
Any suggestions on how to proceed? Thanks in advance.
Andy.-
