I have the Inky Impressions display on a Raspberry Pi Zero W running Raspbian 10. I am using Python 3.7.3
I installed the inky library and all dependencies and was initially able to run a script and display an image on the screen. However, now whenever I try to display a new image the following exception is thrown:
File “”, line 5, in
File “/home/pi/.local/lib/python3.7/site-packages/inky/inky_uc8159.py”, line 365, in show
self._update(buf.astype(‘uint8’).tolist(), busy_wait=busy_wait)
File “/home/pi/.local/lib/python3.7/site-packages/inky/inky_uc8159.py”, line 320, in _update
self.setup()
File “/home/pi/.local/lib/python3.7/site-packages/inky/inky_uc8159.py”, line 226, in setup
self._busy_wait()
File “/home/pi/.local/lib/python3.7/site-packages/inky/inky_uc8159.py”, line 309, in _busy_wait
raise RuntimeError(“Timeout waiting for busy signal to clear.”)
RuntimeError: Timeout waiting for busy signal to clear.
I have exactly the same issue on my RPi Zero W with Raspberry Pi OS Lite ( Release date: May 7th 2021 / Kernel version: 5.10) and an Inky impression display.
I’m not entirely sure what you mean. I’ve found /usr/local/lib/python3.7/dist-packages/inky/inky_uc8159.py and around line 307 I see
def _busy_wait(self, timeout=15.0):
"""Wait for busy/wait pin."""
t_start = time.time()
while not self._gpio.input(self.busy_pin):
time.sleep(0.01)
if time.time() - t_start >= timeout:
raise RuntimeError("Timeout waiting for busy signal to clear.")
What exactly did you modify here? Something like
time.sleep(1)
or did you modify the time.sleep(0.01) to time.sleep(1)?
Yes, either replace that whole code block within the function with the time.sleep, or just change the time.sleep that is there to 30 and leave the rest of the code.
