Extension layers - how many to cover a Unicorn HAT?
There’s a great video of a diffusion layer over a Unicorn HAT.
Please could you let us know how many extension layers are required to fit a diffusion layer over the HAT?
Thank you.
Nigel
I’m assuming you have a PiBow Coupe? ( the one that’s 6 layers in total with a hole for GPIO ) If not, then you can ignore the below and just get a frosted top! I recommend the Ninja top, since I think it looks better.
The video showed the UnicornHAT inside a full-sized PiBow which consists of 4 additional layers- 3 of which are cut around the USB ports.
You would need to get a full-sized PiBow to obtain the right layers- getting extension layers and cutting them yourself would probably lead to breakages, which is not something you want to happen with £8 worth of layers!
If you get a PiBow Ninja and a frosted top, for example, you’ve got options. You could then use your Coupe top to have a Ninja Coupe, or the frosted-top on the Ninja.
Ah, yes, I have a PiBow Coupe.
OK, I’ll get a full size PiBow (just the excuse I needed) and a frosted top.
I think I’ll opt for ‘classic’ rainbow for the full multi-coloured effect.
Thanks for your quick reply!
No problem! Glad to be a provider of excuses ;)
And do post pictures/video when you get it up and running!
