dwc
January 2, 2025, 6:54pm
1
Hi folks.
In this guide:
https://learn.pimoroni.com/article/getting-started-with-clipper-hat
The serial port to connect is given as “/dev/ttyAMA0”.
This is only case on the RPi5, For other board types (I think all) it will be “/dev/ttyS0”.
Is this the right place to get a correction to filter through to the guide?
Cheers
Did you get it working with a Pi4, all I get is a solid green light - even after using the corrected port
dwc
January 11, 2025, 11:11am
3
Yes. Got it working on a Pi3B+, Pi4 & Pi5.
I followed the tutorial exactly, except the serial port on the Pi3B+ and 4.
Where does your’s fail? Do you get an ‘at’?
I get an OK from AT command but I never see the green light flashing.
But I’m using my own sims which work with a different board and our PICO devices.
Was hoping this would work out of the box with Pi4.
Are you using a Sim that was sent with the HAT (i didn’t get one but i see they talk of an offer)
dwc
January 11, 2025, 11:37am
5
The green LED doesn’t flash until after the first connection. Yes, I’m using the sim that came with the unit. Was lucky enough to get a free one with the early offer.
