I just received the hyperpixel 4, and installed it on a Pi Zero-W which I previously had the onoffshim installed on.
When I rebooted the screen, it’s all colour shifted and predominantly green in colour.
I then reinstalled a fresh image and installed the hyperpixel which worked perfectly.
I then installed the onoffshim, and the screen is now again showing green.
So there is obviously a conflict between the onoffshim and the hyperixel.
But how do I now uninstall only the onoffshim without having to wipe everything and start all over again. Again.
Ta. :)
Yup- the HyperPixel uses all the pins.
I believe you can just “sudo systemctl disable cleanshutd”.
Okay, tried that, and… It worked. Ta. :)
It’s a bit rubbish though. You would have thought that the off switch would be compatible. :(
yeah it does suck,but thats the way the Pi goes round,i have gotten in the habit of checking before i try/buy the devices ,i use this to check most hats and ,dont tink the hyperpixel is in the list yet though
https://pinout.xyz/phatstack
It’s the same as the older HyperPixel board when it comes to pin usage- basically ALLL THE PINS - https://pinout.xyz/pinout/hyperpixel
This is because it’s using an 18bit parallel display bus. Sadly unavoidable ;(
