Hyperpixel install/uninstall
If:
curl https://get.pimoroni.com/hyperpixel | bash
installs the HyperPixel screen, then what can I input to uninstall it?
Would something similar to:
‘sudo apt-get purge wolfram-engine’
or:
‘sudo apt-get remove --purge libreoffive*’
work?
Andrew
You can see most of what makes HyperPixel tick in the file /boot/config.txt. Uncomment the lines which are marked as related to HyperPixel, and you’ll be back to HDMI.
You will also want to sudo systemctl disable hyperpixel-touch and sudo systemctl disable hyperpixel-init
that’ll work…
I can also say that GBA games on retropie look great on the hyperpixel screen (just need to work out how to get bluetooth sound o/p working)
