Hi, yes I’ve seen the other threads.
I’ve exported a bdf file from fontforge. But I can’t figure out how to get picographics/inky/micropython to actually load and use an external font. Can anyone share how they did this with success?
Thank you!
Thank you!
Which other threads are you referring to? AFAIK, it is CircuitPython that supports BDF files, not MicroPython. But I might have missed something.
If you read my answer in the cited post, you will see that I am talking about bitmap fonts and not BDF (the link to the guide posted at the end of that thread is a not from me and a bit misleading).
So your way to success is to use fontforge to create a bitmap font of the given size, and then use some obscure tool that you find in the Internet to convert it to a C-header file and then you would patch MicroPython to use your bitmap font instead of the one that is supplied.
Fonts are one of the reasons I use CircuitPython instead of MicroPython.
But Pimoroni added a new feature recently to (at least some of) their builds: “pico-vector” pimoroni-pico/libraries/pico_vector at main · pimoroni/pimoroni-pico · GitHub
Looking at the source code, it seems it can load vector fonts, but all of this is not documented on a user level. But maybe someone else can help here.
