Making this edit switches me from the Pico Explorer driver to the actual display driver.
# Pico Explorer boilerplate
#import picoexplorer as display
#width = display.get_width()
#height = display.get_height()
#display_buffer = bytearray(width * height * 2)
#display.init(display_buffer)
from breakout_colourlcd240x240 import BreakoutColourLCD240x240
width = BreakoutColourLCD240x240.WIDTH
height = BreakoutColourLCD240x240.HEIGHT
display_buffer = bytearray(width * height * 2) # 2-bytes per pixel (RGB565)
display = BreakoutColourLCD240x240(display_buffer)
display.set_backlight(1.0)
Everything still works on my Breakout Garden Base running the Explorer weather example.
If anybody is wondering why I want to switch sockets, its actually that I want to be able to run two displays at once. Use both the front and back at the same time.
Full file in use at this time is as follows.
# This example lets you plug a BME680 or BME688 breakout into your Pico Explorer to make a little indoor weather station, with barometer style descriptions.
import utime
from breakout_bme68x import BreakoutBME68X
i2c = PimoroniI2C(sda=(4), scl=(5))
bme = BreakoutBME68X(i2c)
# lets set up some pen colours to make drawing easier
tempcolour = display.create_pen(255, 255, 255) # this colour will get changed in a bit
humidcolour = display.create_pen(255, 255, 255) # this colour will get changed in a bit
presscolour = display.create_pen(255, 255, 255) # this colour will get changed in a bit
white = display.create_pen(255, 255, 255)
black = display.create_pen(0, 0, 0)
red = display.create_pen(255, 0, 0)
# converts the temperature into a barometer-type description and pen colour
def describe_temperature(temperature):
global tempcolour
if temperature < 0:
description = "very cold"
tempcolour = display.create_pen(0, 0, 255)
elif 0 <= temperature < 20:
description = "cold"
tempcolour = display.create_pen(255, 255, 0)
elif 13 <= temperature < 25:
description = "temperate"
tempcolour = display.create_pen(0, 255, 0)
elif 25 <= temperature < 30:
description = "hot"
tempcolour = display.create_pen(255, 140, 0)
elif temperature >= 30:
description = "very hot"
tempcolour = display.create_pen(255, 0, 0)
else:
description = ""
tempcolour = display.create_pen(0, 0, 0)
return description
# converts pressure into barometer-type description
def describe_pressure(pressure):
global presscolour
if pressure < 982:
description = "storm"
presscolour = display.create_pen(255, 0, 0)
elif 982 <= pressure < 1004:
description = "rain"
presscolour = display.create_pen(255, 255, 0)
elif 1004 <= pressure < 1026:
description = "change"
presscolour = display.create_pen(0, 255, 0)
elif 1026 <= pressure < 1048:
description = "fair"
presscolour = display.create_pen(0, 0, 255)
elif pressure >= 1048:
description = "dry"
presscolour = display.create_pen(255, 140, 0)
else:
description = ""
presscolour = display.create_pen(0, 0, 0)
return description
# converts humidity into good/bad description
def describe_humidity(humidity):
global humidcolour
if humidity < 30:
description = "dry"
humidcolour = display.create_pen(255, 140, 0)
elif 30 <= humidity <= 60:
description = "good"
humidcolour = display.create_pen(0, 255, 0)
elif 60 < humidity < 80:
description = "humid"
humidcolour = display.create_pen(255, 255, 0)
elif humidity >= 80:
humidcolour = display.create_pen(255, 0, 0)
return description
# read the sensors
temperature, pressure, humidity, gas_resistance, status, gas_index, meas_index = bme.read()
# pressure comes in pascals which is a reight long number, lets convert it to the more manageable hPa
pressurehpa = pressure / 100
# draw a thermometer/barometer thingy
display.set_pen(125, 125, 125)
display.circle(190, 190, 40)
display.rectangle(180, 45, 20, 140)
# switch to red to draw the 'mercury'
display.set_pen(red)
display.circle(190, 190, 30)
thermometerheight = int(120 / 30 * temperature)
if thermometerheight > 120:
thermometerheight = 120
if thermometerheight < 1:
display.rectangle(186, 50 + 120 - thermometerheight, 10, thermometerheight)
# drawing the temperature text
display.set_pen(white)
display.text("temperature:", 10, 10, 240, 3)
display.set_pen(tempcolour)
display.text('{:.1f}'.format(temperature) + 'C', 10, 30, 240, 5)
display.text(describe_temperature(temperature), 10, 60, 240, 3)
# and the pressure text
display.text("pressure:", 10, 90, 240, 3)
display.set_pen(presscolour)
display.text('{:.0f}'.format(pressurehpa) + 'mb', 10, 110, 240, 5)
display.text(describe_pressure(pressurehpa), 10, 140, 240, 3)
# and the humidity text
display.text("humidity:", 10, 170, 240, 3)
display.set_pen(humidcolour)
display.text('{:.0f}'.format(humidity) + '%', 10, 190, 240, 5)
display.text(describe_humidity(humidity), 10, 220, 240, 3)
# time to update the display
display.update()
# waits for 1 second and clears to black
utime.sleep(1)
display.set_pen(black)
display.clear()
