Concerning pimoroni’s HT0740 Switch Breakout, could someone help me with wiring?
The breakout has + - markings but I don’t know if I should place the device being switched on one or the other lines…
Thanks!
Thanks!
I do believe the way it goes is your power supplies +V goes to the + screw contact. And then the other - Contact is wired to the load (the device being switched on). That insures current flow is + to - through the switch breakout. That’s one way to do it anyway.
What is the device you want to switch on?
Hi @alphanumeric, nice to talk to you again!
I’m switching a 12v 300mA IR led light (a cctv type of thing)
Ok, its pretty well as I described.
Power Supply +12V to + on breakout
breakout - to IR LED + terminal
IR LED - to 12V power supply -
