Hello.
I purchased a HyperPixel 4.0 non-touch from Adafruit and I did everything that the repo says (one-liner, checking the i2c device which is 11 in my case and link it to i2c-1) and I cannot make the screen work as it should be. When the Pi boots I can see the desktop for a moment and then it is all black screen.
I’m using a Pi400 with an Adafruit CyberDeck but also tested the screen on a Pi 4 8GB and it’s the same (same SD by the way).
Any help will be highly appreciated.
Here’s my debug information:
pi@raspberrypi:~/hyperpixel4 $ ./hyperpixel4-debug.sh
Platform Information
Revision : c03130
Description: Raspbian GNU/Linux 10 (buster)
5.10.17-v7l+
Touchscreen logs
Rectangular: Goodix
[ 5.943507] Goodix-TS 11-0014: supply AVDD28 not found, using dummy regulator
[ 5.943911] Goodix-TS 11-0014: supply VDDIO not found, using dummy regulator
[ 5.944725] Goodix-TS 11-0014: i2c test failed attempt 1: -6
[ 5.984442] Goodix-TS 11-0014: i2c test failed attempt 2: -6
[ 6.033794] Goodix-TS 11-0014: I2C communication failure: -6
Square: ft5
I2C Devices and Mappings
/dev/i2c-1
/dev/i2c-11
00: – – – – – – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – – – – – – – – –
50: – – – – – – – – – – – – – – – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
Boot Config
For more options and information see
http://rpf.io/configtxt
Some settings may impact device functionality. See link above for details
uncomment if you get no picture on HDMI for a default “safe” mode
#hdmi_safe=1
uncomment this if your display has a black border of unused pixels visible
and your display can output without overscan
#disable_overscan=1
uncomment the following to adjust overscan. Use positive numbers if console
goes off screen, and negative if there is too much border
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
uncomment to force a console size. By default it will be display’s size minus
overscan.
#framebuffer_width=1280
#framebuffer_height=720
uncomment if hdmi display is not detected and composite is being output
#hdmi_force_hotplug=1
uncomment to force a specific HDMI mode (this will force VGA)
#hdmi_group=1
#hdmi_mode=1
uncomment to force a HDMI mode rather than DVI. This can make audio work in
DMT (computer monitor) modes
#hdmi_drive=2
uncomment to increase signal to HDMI, if you have interference, blanking, or
no display
#config_hdmi_boost=4
uncomment for composite PAL
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
Uncomment some or all of these to enable the optional hardware interfaces
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
Uncomment this to enable infrared communication.
#dtoverlay=gpio-ir,gpio_pin=17
#dtoverlay=gpio-ir-tx,gpio_pin=18
Additional overlays and parameters are documented /boot/overlays/README
Enable audio (loads snd_bcm2835)
dtparam=audio=on
[pi4]
Enable DRM VC4 V3D driver on top of the dispmanx display stack
dtoverlay=vc4-fkms-v3d
max_framebuffers=2
[all]
#dtoverlay=vc4-fkms-v3d
dtoverlay=hyperpixel4
enable_dpi_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x7f216
dpi_timings=480 0 10 16 59 800 0 15 113 15 0 0 0 60 0 32000000 6
