PLEASE NOTE
:warning: GitHub issues are for reporting problems with the software, tech support do not monitor these.
Our software team are smol and busy, and you will not receive a timely response.
If you’re having a hardware issue with your Hyperpixel 4, you should contact support@pimoroni.com.
:warning: Hyperpixel 4 is only officially supported on Raspberry Pi OS. There are too many operating systems with too many quirks to begin to support them all. Issues relating to other operating systems will be closed.
Describe the bug
The display works perfect until I set the pi to start into desktop. I can see it goes through the boot sequence but once it startx it goes black (but still backlit). I’ve skinned this cat 9 different ways and every variation produces the same results. Console good, X bad.
To Reproduce
sudo apt update
sudo apt upgrade
sudo apt dist-upgrade
sudo apt clean
sudo reboot
sudo /home/addohm/scripts/install-desktop
sudo reboot
git clone GitHub - pimoroni/hyperpixel4: Driver for the Pimoroni HyperPixel 4.0" Touchscreen Display -b pi4
cd hyperpixel4
sudo ./install.sh
edit /boot/config.txt - dtoverlay=vc4-fkms-v3d
sudo reboot
(Display works at this point)
sudo raspi-config - boot to desktop
(Display stops working once boot reaches startx)
Your HyperPixel 4
Let us know which HyperPixel 4 board you’re using. Note: if you’re having a problem with the original HyperPixel you should go to: GitHub - pimoroni/hyperpixel: Setup for the Pimoroni Hyper Pixel 800x480 pixel multi-touch display
- Is it Square or Rectangular?
- Touch or non Touch?
- Approximately when was it purchased
Last week - How is it connected to your Pi
Directly using the riser header
Your Raspberry Pi
Give as much detail about your Pi and OS as possible. We only officially support Raspbian, but might be able to point you in the right direction if the problem is with another OS.
What model of Raspberry Pi are you using (the result of
cat /proc/cpuinfo | grep Revisioncan tell us this exactly
Revision : b03115 -
Which OS release are you using:
lsb_release --descriptionanduname -r
Description: Raspbian GNU/Linux 11 (bullseye) -
Is this a fresh OS setup, or one you might have previously installed scripts/add-ons on?
“Other specific purpose OS” > Octopi
Extra debugging information
If you’re having a problem with touch, try checking dmesg for related errors:
dmesg | grep Goodixfor HyperPixel 4.0" Rectangular*
[ 7.119080] Goodix-TS 22-0014: supply AVDD28 not found, using dummy regulator
[ 7.119487] Goodix-TS 22-0014: supply VDDIO not found, using dummy regulator
[ 7.126802] Goodix-TS 22-0014: Error reading 1 bytes from 0x8140: -6
[ 7.154612] Goodix-TS 22-0014: Error reading 1 bytes from 0x8140: -6
[ 7.181055] Goodix-TS 22-0014: I2C communication failure: -6 -
dmesg | grep ft5for HyperPixel 4.0" Square
And check i2c is working:
ls /dev/i2c-*
/dev/i2c-22
You should see something like:
pi@raspberrypi:~ $ ls /dev/i2c-*
/dev/i2c-7
And your HyperPixel 4 touch is showing up (there should be an address blocked out with UU in the below command):
i2cdetect -y X ( where X is the number of i2c bus found in the command above)
For example:
pi@raspberrypi:~ $ i2cdetect -y 7
00: -- -- -- -- -- -- -- -- -- -- -- -- --
10: -- -- -- -- UU -- -- -- -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
00: – – – – – – – –
10: – – – – – – – – – – – – – – – –
20: – – – – – – – – – – – – – – – –
30: – – – – – – – – – – – – – – – –
40: – – – – – – – – – – – – – – – –
50: – – – – – – – – – – – – – 5d – –
60: – – – – – – – – – – – – – – – –
70: – – – – – – – –
