Hyperpixel - display not working with 'FullPage OS' Raspbian based distro
Hi folks,
(SOLUTION: Comment out the original FullPageOS ‘dtoverlay’ which makes the HyperPixel ‘dtoverlay’ line the default one - within config.txt on /boot)
To begin with - my HyperPixel works fine (except for some peculiarities, which I can detail in another post) based on latest stretch and following the Pimoroni install instructions on Github
After this, I got another SD card and installed ‘FullPageOS’ on a Raspberry Pi 2 ver 1.2.
  • FullPageOS: A Raspberry Pi distribution to display one webpage in full screen. It includes Chromium out of the box and the scripts necessary to load it at boot. This repository contains the source script to generate the distribution out of an existing Raspbian distro image.
I then did update / upgrade the distro - and then cloned the HyperPixel repository and ran setup.sh
Everything seemed to run smoothly, with SSH working as VNC service showing that the default app ‘FullPageDashboard’ was working on Chomium remotely…
(You can see more context here - in the issue I raised on ‘FullPage OS Github site’)
Please see output of ‘systemctl --full | cat’ further below.
Hoping someone can identify an issue there…
Cheers,
Michael.
 LOAD   ACTIVE SUB       DESCRIPTION
proc-sys-fs-binfmt_misc.automount                                                               loaded active waiting   Arbitrary Executable File Formats File System Automount Point
sys-devices-platform-rpi_backlight-backlight-rpi_backlight.device                               loaded active plugged   /sys/devices/platform/rpi_backlight/backlight/rpi_backlight
sys-devices-platform-soc-3f201000.serial-tty-ttyAMA0-hci0.device                                loaded active plugged   /sys/devices/platform/soc/3f201000.serial/tty/ttyAMA0/hci0
sys-devices-platform-soc-3f201000.serial-tty-ttyAMA0.device                                     loaded active plugged   /sys/devices/platform/soc/3f201000.serial/tty/ttyAMA0
sys-devices-platform-soc-3f202000.sdhost-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p1.device loaded active plugged   /sys/devices/platform/soc/3f202000.sdhost/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p1
sys-devices-platform-soc-3f202000.sdhost-mmc_host-mmc0-mmc0:0001-block-mmcblk0-mmcblk0p2.device loaded active plugged   /sys/devices/platform/soc/3f202000.sdhost/mmc_host/mmc0/mmc0:0001/block/mmcblk0/mmcblk0p2
sys-devices-platform-soc-3f202000.sdhost-mmc_host-mmc0-mmc0:0001-block-mmcblk0.device           loaded active plugged   /sys/devices/platform/soc/3f202000.sdhost/mmc_host/mmc0/mmc0:0001/block/mmcblk0
sys-devices-platform-soc-3f300000.mmc-mmc_host-mmc1-mmc1:0001-mmc1:0001:1-net-wlan0.device      loaded active plugged   /sys/devices/platform/soc/3f300000.mmc/mmc_host/mmc1/mmc1:0001/mmc1:0001:1/net/wlan0
sys-devices-platform-soc-3f902000.hdmi-sound-card1.device                                       loaded active plugged   /sys/devices/platform/soc/3f902000.hdmi/sound/card1
sys-devices-platform-soc-3f980000.usb-usb1-1\x2d1-1\x2d1.1-1\x2d1.1:1.0-net-eth0.device         loaded active plugged   SMSC9512/9514 Fast Ethernet Adapter
sys-devices-platform-soc-soc:audio-sound-card0.device                                           loaded active plugged   /sys/devices/platform/soc/soc:audio/sound/card0
sys-devices-virtual-block-ram0.device                                                           loaded active plugged   /sys/devices/virtual/block/ram0
sys-devices-virtual-block-ram1.device                                                           loaded active plugged   /sys/devices/virtual/block/ram1
sys-devices-virtual-block-ram10.device                                                          loaded active plugged   /sys/devices/virtual/block/ram10
sys-devices-virtual-block-ram11.device                                                          loaded active plugged   /sys/devices/virtual/block/ram11
sys-devices-virtual-block-ram12.device                                                          loaded active plugged   /sys/devices/virtual/block/ram12
sys-devices-virtual-block-ram13.device                                                          loaded active plugged   /sys/devices/virtual/block/ram13
sys-devices-virtual-block-ram14.device                                                          loaded active plugged   /sys/devices/virtual/block/ram14
sys-devices-virtual-block-ram15.device                                                          loaded active plugged   /sys/devices/virtual/block/ram15
sys-devices-virtual-block-ram2.device                                                           loaded active plugged   /sys/devices/virtual/block/ram2
sys-devices-virtual-block-ram3.device                                                           loaded active plugged   /sys/devices/virtual/block/ram3
sys-devices-virtual-block-ram4.device                                                           loaded active plugged   /sys/devices/virtual/block/ram4
sys-devices-virtual-block-ram5.device                                                           loaded active plugged   /sys/devices/virtual/block/ram5
sys-devices-virtual-block-ram6.device                                                           loaded active plugged   /sys/devices/virtual/block/ram6
sys-devices-virtual-block-ram7.device                                                           loaded active plugged   /sys/devices/virtual/block/ram7
sys-devices-virtual-block-ram8.device                                                           loaded active plugged   /sys/devices/virtual/block/ram8
sys-devices-virtual-block-ram9.device                                                           loaded active plugged   /sys/devices/virtual/block/ram9
sys-devices-virtual-misc-rfkill.device                                                          loaded active plugged   /sys/devices/virtual/misc/rfkill
sys-devices-virtual-tty-ttyprintk.device                                                        loaded active plugged   /sys/devices/virtual/tty/ttyprintk
sys-module-configfs.device        loaded active plugged   /sys/module/configfs
sys-subsystem-bluetooth-devices-hci0.device                                                     loaded active plugged   /sys/subsystem/bluetooth/devices/hci0
sys-subsystem-net-devices-eth0.device                                                           loaded active plugged   SMSC9512/9514 Fast Ethernet Adapter
sys-subsystem-net-devices-wlan0.device                                                          loaded active plugged   /sys/subsystem/net/devices/wlan0
-.mount        loaded active mounted   Root Mount
boot.mount        loaded active mounted   /boot
dev-mqueue.mount        loaded active mounted   POSIX Message Queue File System
run-rpc_pipefs.mount        loaded active mounted   RPC Pipe File System
run-user-1000.mount        loaded active mounted   /run/user/1000
sys-kernel-config.mount        loaded active mounted   Configuration File System
sys-kernel-debug.mount        loaded active mounted   Debug File System
systemd-ask-password-plymouth.path                                                              loaded active waiting   Forward Password Requests to Plymouth Directory Watch
systemd-ask-password-wall.path        loaded active waiting   Forward Password Requests to Wall Directory Watch
init.scope        loaded active running   System and Service Manager
session-c1.scope        loaded active running   Session c1 of user pi
session-c2.scope        loaded active running   Session c2 of user pi
alsa-restore.service        loaded active exited    Save/Restore Sound Card State
avahi-daemon.service        loaded active running   Avahi mDNS/DNS-SD Stack
bluetooth.service        loaded active running   Bluetooth service
console-setup.service        loaded active exited    Set console font and keymap
cron.service        loaded active running   Regular background program processing daemon
dbus.service        loaded active running   D-Bus System Message Bus
dhcpcd.service        loaded active running   dhcpcd on all interfaces
dphys-swapfile.service        loaded active exited    LSB: Autogenerate and use a swap file
fake-hwclock.service        loaded active exited    Restore / save the current clock
getty@tty1.service        loaded active running   Getty on tty1
hciuart.service        loaded active running   Configure Bluetooth Modems connected by UART
hyperpixel-touch.service        loaded active running   Hyperpixel LCD Touch Screen Driver Daemon
keyboard-setup.service        loaded active exited    Set the console keyboard layout
kmod-static-nodes.service        loaded active exited    Create list of required static device nodes for the current kernel
lightdm.service        loaded active running   Light Display Manager
lighttpd.service        loaded active running   Lighttpd Daemon
networking.service        loaded active exited    Raise network interfaces
raspi-config.service        loaded active exited    LSB: Switch to ondemand cpu governor (unless shift key is pressed)
rc-local.service        loaded active exited    /etc/rc.local Compatibility
rsyslog.service        loaded active running   System Logging Service
ssh.service        loaded active running   OpenBSD Secure Shell server
systemd-backlight@backlight:rpi_backlight.service                                               loaded active exited    Load/Save Screen Backlight Brightness of backlight:rpi_backlight
systemd-fsck-root.service        loaded active exited    File System Check on Root Device
systemd-fsck@dev-disk-by\x2dpartuuid-3c403521\x2d01.service                                     loaded active exited    File System Check on /dev/disk/by-partuuid/3c403521-01
systemd-journal-flush.service        loaded active exited    Flush Journal to Persistent Storage
systemd-journald.service        loaded active running   Journal Service
systemd-logind.service        loaded active running   Login Service
systemd-modules-load.service        loaded active exited    Load Kernel Modules
systemd-random-seed.service        loaded active exited    Load/Save Random Seed
systemd-remount-fs.service        loaded active exited    Remount Root and Kernel File Systems
systemd-sysctl.service        loaded active exited    Apply Kernel Variables
systemd-timesyncd.service        loaded active running   Network Time Synchronization
systemd-tmpfiles-setup-dev.service                                                              loaded active exited    Create Static Device Nodes in /dev
systemd-tmpfiles-setup.service        loaded active exited    Create Volatile Files and Directories
systemd-udev-trigger.service        loaded active exited    udev Coldplug all Devices
systemd-udevd.service        loaded active running   udev Kernel Device Manager
systemd-update-utmp.service        loaded active exited    Update UTMP about System Boot/Shutdown
systemd-user-sessions.service        loaded active exited    Permit User Sessions
triggerhappy.service        loaded active running   triggerhappy global hotkey daemon
user@1000.service        loaded active running   User Manager for UID 1000
-.slice        loaded active active    Root Slice
system-getty.slice        loaded active active    system-getty.slice
system-systemd\x2dbacklight.slice                                                               loaded active active    system-systemd\x2dbacklight.slice
system-systemd\x2dfsck.slice        loaded active active    system-systemd\x2dfsck.slice
system.slice        loaded active active    System Slice
user-1000.slice        loaded active active    User Slice of pi
user.slice        loaded active active    User and Session Slice
avahi-daemon.socket        loaded active running   Avahi mDNS/DNS-SD Stack Activation Socket
dbus.socket        loaded active running   D-Bus System Message Bus Socket
syslog.socket        loaded active running   Syslog Socket
systemd-fsckd.socket        loaded active listening fsck to fsckd communication Socket
systemd-initctl.socket        loaded active listening /dev/initctl Compatibility Named Pipe
systemd-journald-dev-log.socket        loaded active running   Journal Socket (/dev/log)
systemd-journald.socket        loaded active running   Journal Socket
systemd-rfkill.socket        loaded active listening Load/Save RF Kill Switch Status /dev/rfkill Watch
systemd-udevd-control.socket        loaded active running   udev Control Socket
systemd-udevd-kernel.socket        loaded active running   udev Kernel Socket
triggerhappy.socket        loaded active running   triggerhappy.socket
var-swap.swap        loaded active active    /var/swap
basic.target        loaded active active    Basic System
bluetooth.target        loaded active active    Bluetooth
cryptsetup.target        loaded active active    Encrypted Volumes
getty.target        loaded active active    Login Prompts
graphical.target        loaded active active    Graphical Interface
local-fs-pre.target        loaded active active    Local File Systems (Pre)
local-fs.target        loaded active active    Local File Systems
multi-user.target        loaded active active    Multi-User System
network.target        loaded active active    Network
nfs-client.target        loaded active active    NFS client services
paths.target        loaded active active    Paths
remote-fs-pre.target        loaded active active    Remote File Systems (Pre)
remote-fs.target        loaded active active    Remote File Systems
slices.target        loaded active active    Slices
sockets.target        loaded active active    Sockets
sound.target        loaded active active    Sound Card
swap.target        loaded active active    Swap
sysinit.target        loaded active active    System Initialization
time-sync.target        loaded active active    System Time Synchronized
timers.target        loaded active active    Timers
apt-daily-upgrade.timer        loaded active waiting   Daily apt upgrade and clean activities
apt-daily.timer        loaded active waiting   Daily apt download activities
phpsessionclean.timer        loaded active waiting   Clean PHP session files every 30 mins
systemd-tmpfiles-clean.timer        loaded active waiting   Daily Cleanup of Temporary Directories
LOAD   = Reflects whether the unit definition was properly loaded.
ACTIVE = The high-level unit activation state, i.e. generalization of SUB.
SUB    = The low-level unit activation state, values depend on unit type.
128 loaded units listed. Pass --all to see loaded but inactive units, too.
To show all installed unit files use 'systemctl list-unit-files'.
I may be missing something, but I don’t think you’ve described a problem? What’s not working on the HyperPixel with FullPage OS?
Yeap, explaining my issue would be handy 😝
Basically no display from HyperPixel, just the backlight on but no display of Chomium as is supposed to happen with FullPageOs.
I can ssh in and see Chromium over VNC but HyperPixel shows nothing.
Hi @gadgetoid !
Any illumination on this would be most welcome…
Any other files you need to assess root issue?
Cheers,
Michael.
Curious, what do you see in your /boot/config.txt on the FullPageOS setup?
I just had a quick dig through their GitHub repo and it seems like nothing more than a couple of scripts that run on boot to run a webserver and full-screen browser instance.
Also what process did you use to update/upgrade the distro?
Hi @gadgetoid
Before HyperPixel install - only three lines were active / uncommented in config.txt on /boot as follows -
dtparam=audio=on
start_x=1
dtoverlay=vc4-kms-v3d
Above was taken after initial sudo update and upgrade. Please see ‘BeforeHyperPixel_Config.txt’ as follows -
# For more options and information see
# http://rpf.io/configtxt
# Some settings may impact device functionality. See link above for details
# uncomment if you get no picture on HDMI for a default "safe" mode
# hdmi_safe=1
# uncomment this if your display has a black border of unused pixels visible
# and your display can output without overscan
# disable_overscan=1
# uncomment the following to adjust overscan. Use positive numbers if console
# goes off screen, and negative if there is too much border
# overscan_left=16
# overscan_right=16
# overscan_top=16
# overscan_bottom=16
# uncomment to force a console size. By default it will be display's size minus
# overscan.
# framebuffer_width=1280
# framebuffer_height=720
# uncomment if hdmi display is not detected and composite is being output
# hdmi_force_hotplug=1
# uncomment to force a specific HDMI mode (this will force VGA)
# hdmi_group=1
# hdmi_mode=1
# uncomment to force a HDMI mode rather than DVI. This can make audio work in
# DMT (computer monitor) modes
# hdmi_drive=2
# uncomment to increase signal to HDMI, if you have interference, blanking, or
# no display
# config_hdmi_boost=4
# uncomment for composite PAL
# sdtv_mode=2
# uncomment to overclock the arm. 700 MHz is the default.
# arm_freq=800
# Uncomment some or all of these to enable the optional hardware interfaces
# dtparam=i2c_arm=on
# dtparam=i2s=on
# dtparam=spi=on
# Uncomment this to enable the lirc-rpi module
# dtoverlay=lirc-rpi
# Additional overlays and parameters are documented /boot/overlays/README
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# enable raspicam
start_x=1
# gpu_mem=128
After cloning Hyperpixel repo and installing same under sudo (and rebooting) I took another snapshot of config.txt named - AfterHyperPixel_Config.txt which can be seen below…
#hdmi_safe=1
#disable_overscan=1
#overscan_left=16
#overscan_right=16
#overscan_top=16
#overscan_bottom=16
# overscan.
#framebuffer_width=1280
#framebuffer_height=720
#hdmi_force_hotplug=1
#hdmi_group=1
#hdmi_mode=1
#hdmi_drive=2
# no display
#config_hdmi_boost=4
#sdtv_mode=2
#uncomment to overclock the arm. 700 MHz is the default.
#arm_freq=800
#dtparam=i2c_arm=on
#dtparam=i2s=on
#dtparam=spi=on
#dtoverlay=lirc-rpi
dtparam=audio=on
# enable raspicam
start_x=1
#gpu_mem=128
# HyperPixel LCD Settings
dtoverlay=hyperpixel
overscan_left=0
overscan_right=0
overscan_top=0
overscan_bottom=0
framebuffer_width=800
framebuffer_height=480
enable_dpi_lcd=1
display_default_lcd=1
dpi_group=2
dpi_mode=87
dpi_output_format=0x6f016
display_rotate=2
hdmi_timings=800 0 50 20 50 480 1 3 2 3 0 0 0 60 0 32000000 6
# Use a basic GPIO backlight driver with on/off support
dtoverlay=hyperpixel-gpio-backlight
Just a note, FullPageOs does not have full Raspbian ‘Pixel’ - just a chromium app that allows extra tabs to be created.
Regards,
Michael.
Hey!
I noticed there was two ‘dtoverlys’, one original and one that HyperPixel introduced…
So I commented out the original ‘dtoverlay=vc4-kms-v3d’ - leaving the ‘dtoverlay=hyperpixel’ to be the default - and hey presto, it works!
Cheers,
Michael
