When running the install script, I get the following msg back:
E: Repository ‘Index of /debian buster InRelease’ changed its ‘Suite’ value from ‘testing’ to ‘oldstable’
and then that Apt failed to update indexes
Now what do I do?
Now what do I do?
Run sudo apt update and sudo apt upgrade manually from terminal first.
That should get you a prompt about the stable to old stable that you can answer Y too.
Hah! I was just doing that, then I saw your msg. Thanks
