Hi Support,
I got Hyperpixel Touch 2.1 Round working on Trixie but I’m unable to get touch to work nor I2C on Hyperpixel dedicated I2C connector.
Please don’t tell me to read documentation, just done 3 times, it just does not work. I also read other posts here, looks like I’m not the only one.
Here is my config
Raspberry Pi Zero W / Raspian Trixie updated latest
Here is my config.txt (Disabled I2C/SPI and Serial)
# For more options and information see
# http://rptl.io/configtxt
# Some settings may impact device functionality. See link above for details
# Uncomment some or all of these to enable the optional hardware interfaces
dtparam=i2c_arm=off
#dtparam=i2s=on
dtparam=spi=off
# Enable audio (loads snd_bcm2835)
dtparam=audio=on
# Additional overlays and parameters are documented
# /boot/firmware/overlays/README
# Automatically load overlays for detected cameras
camera_auto_detect=1
# Automatically load overlays for detected DSI displays
display_auto_detect=1
# Automatically load initramfs files, if found
auto_initramfs=0
# Enable DRM VC4 V3D driver
dtoverlay=vc4-kms-v3d
max_framebuffers=2
# Don't have the firmware create an initial video= setting in cmdline.txt.
# Use the kernel's default instead.
disable_fw_kms_setup=1
# Disable compensation for displays with overscan
disable_overscan=1
# Run as fast as firmware / board allows
arm_boost=1
[cm4]
# Enable host mode on the 2711 built-in XHCI USB controller.
# This line should be removed if the legacy DWC2 controller is required
# (e.g. for USB device mode) or if USB support is not required.
otg_mode=1
[cm5]
dtoverlay=dwc2,dr_mode=host
[pi5]
dtoverlay=nospi10
[all]
enable_uart=0
disable_splash=1
boot_delay=0
# Pimoroni HyperPixel 2.1 Round (480x480, tactile)
dtoverlay=vc4-kms-dpi-hyperpixel2r
and here what I see on I2C buses
pi@zero-c4f5:~ $ ls /dev/i2c*
/dev/i2c-2
pi@zero-c4f5:~ $ sudo i2cdetect -y 2
00: -- -- -- -- -- -- -- --
70: -- -- -- -- -- -- -- --
pi@zero-c4f5:~ $
whatever I connect on Hyperpixel I2C connector I just see nothing and missing `/dev/i2c-11`
What should I do to at least have touch working? I bought this one for this feature
